Frame-Relay Switching Again?
newnetman
Hello All,
I am receiving the following error message on a router intended for the frame-relay switching. Even though the router has been configured as a FRAME RELAY SWITCHING. Though i did not configure any IP on the interface as i don't need one to the best of my knowledge or am i wrong? or where am i missing something out? please help me.
HERE IS THE ERROR MESSAGE ( the cable side is DCE already)
"Router(config-if)#clock rate 56000
%Error: This command applies only to DCE interfaces
Router(config-if)#
Edison Ortiz
show controller serial x/x | i DTE|DCE
should tell you if the interface is acting as DCE or DTE.
