Frame-Relay Switching
newnetman
Hello All,
In order to practice frame relay, i configured the following "frame-relay switching" in global int, and "frame-relay intf-type dce" at the int level on these routers (2522, 2621 and 2611XM to one of them a frame relay switch. Unfortunately the command " frame-relay intf-type dce" was not accepted on the three router platforms mentioned.
Are mine doing anything wrong? Somebody please help me out.
cisco_lad2004
Level 5
Level 5
configure the interfaces encapsulation to FR
Sam
Edison Ortiz
This link will guide you on how to configure frame-relay on back-to-back.
http://www.internetworkexpert.com/resources/compound.frame-relay.htm
