01-17-2006 02:22 PM - edited 03-03-2019 11:29 AM
I have a frame relay T1 connected to a T1-CSU/DSU WIC (WIC-1DSU-T1) in a 3620 router right now. I have that frame T1 carved up into several 64kbps point-to-point DLCIs right now.
I need to move that T1, along with the same config, over to a 7206-VXR NP-300 router (I'm de-commisioning the 3620 router). What module do I need for that router?
I have a 4-port multi-channel T1/PRI (PA-MC-4T1) I can put in the 7206 --- will that work?
Solved! Go to Solution.
01-17-2006 03:19 PM
G'day,
Yes, you can certainly use that in a 7206-VXR. The card is a multichannel T1 card, which will support channelized interfaces in the same way you are using your T1 on your 3620.
Hope that helps - pls rate the post if it does.
Paresh.
01-17-2006 03:19 PM
G'day,
Paresh.
