Frame Relay Traffic Shaping - Shaping Inactive?
m-carey
I've turned on Frame Relay traffic shaping, but it is still inactive even though it looks like I'm getting BECN's:
GATEWAY#show frame pvc 37
PVC Statistics for interface Serial0/0 (Frame Relay DTE)
DLCI = 37, DLCI USAGE = LOCAL, PVC STATUS = ACTIVE, INTERFACE = Serial0/0.37
input pkts 14250077 output pkts 14189640 in bytes 2836733997
out bytes 1084892581 dropped pkts 819 in FECN pkts 0
in BECN pkts 798 out FECN pkts 0 out BECN pkts 0
in DE pkts 494058 out DE pkts 0
out bcast pkts 81783 out bcast bytes 27233739
5 minute input rate 17000 bits/sec, 18 packets/sec
5 minute output rate 53000 bits/sec, 21 packets/sec
Shaping adapts to BECN
pvc create time 8w0d, last time pvc status changed 1d09h
cir 120000 bc 120000 be 8000 byte limit 2875 interval 125
mincir 128000 byte increment 1875 Adaptive Shaping BECN
pkts 4878991 bytes 1645197084 pkts delayed 1124461 bytes delayed 934316356
shaping inactive
traffic shaping drops 0
Queueing strategy: fifo
Output queue 0/40, 819 drop, 1124461 dequeued
Here is my config:
interface Serial0/0
no ip address
encapsulation frame-relay IETF
no ip route-cache
no ip mroute-cache
no fair-queue
frame-relay traffic-shaping
frame-relay lmi-type ansi
interface Serial0/0.37 point-to-point
description Frame Relay to Healthpoint
bandwidth 128000
ip address 10.1.4.3 255.255.255.0
no ip route-cache
no ip mroute-cache
frame-relay class GHS128K
frame-relay interface-dlci 37
map-class frame-relay GHS128K
frame-relay traffic-rate 120000 128000
frame-relay adaptive-shaping becn
frame-relay cir 128000
frame-relay bc 120000
frame-relay be 8000
frame-relay mincir 128000
I am not 100% sure about this, but can you try and apply the class under the DLCI ?
bandwidth 128000
no ip route-cache
no ip mroute-cache
--> class GHS128K
GP
