02-08-2008 08:44 AM - edited 03-03-2019 08:37 PM
Hi all,
I have an issue where I will have to change the traffic shaping parameters. This will be done off hours, but I am wondering what the best practice for this is. Should I edit the current map-class or create another map-class and swap out the interface configuration. Here is the configuration I will be changing.
Change from:
map-class frame-relay shapeforT1
frame-relay cir 768000
frame-relay bc 7680
frame-relay be 0
service-policy output IPFRCOS
Change to:
frame-relay cir 729600
frame-relay bc 7296
frame-relay be 0
Thanks in advance.
02-08-2008 10:38 AM
You could edit the current map-class without any problems. I've done it plenty of times.
___
Edison.
02-08-2008 12:23 PM
I would just edit the current map, especially if traffic will be low.
