Frame Relay with NM-1T3/E3 card multiple locations
pgershkovich
Hello, could some one help me with this setup or a sample config, I would really use some help. Here is what i have in main router 3660(MR) with NM-1T3/E3 in slot3 and 3 routers(RR#) 2800 in remote locations wit T1 card. I need to connect MR to RR1, RR2 and RR3 using frame relay <- DS3 frame relay provided by verizon. How do i configure T3 card on the MR and frame relay to/and config for RR#. Thank you very much for your help
thisisshanky
Level 11
Level 11
What kind of T3 is it ? Full, sub rate ? Clear channel, channelized ??
Check some of these guides:
http://www.cisco.com/en/US/products/sw/iosswrel/ps5207/products_configuration_guide_chapter09186a008020eced.html
Is there any frame-relay to ATM internetworking involved ?
Check this guide for Frame-relay configurations:
http://www.cisco.com/en/US/products/sw/iosswrel/ps1831/products_configuration_guide_chapter09186a0080087d01.html
If its a clear channel t3 or channelized t3, there will be a serial interface associated with it where you can specify encapsulation as Frame-relay (ietf or cisco) and use the above guide to setup the Main 3660.
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
