frame-relay with ospf not working
slimgrim
hi everyone i have a problem i configued 3 router with frame-relay ietf with ansi lmi
but they don't ping each other  ,you'll find the commands in a text file and  a screenshot  bellow
post your zipped Packet Tracer project (.pkt) file...
Done you can check it
there were several mistakes in your config:
--> ANSI type on the cloud was set to cisco (default)
--> several area mismatches in your OSPF config
--> network 192.168.1.0/24 advertised on all routers (non-existing network)
--> missing mappings and neighbor commands (assuming that what you want is a full mesh)
Attached the revised file(saved in PT version 8.1). It takes a while for OSPF to converge (several minutes).
balaji.bandi
First, you need to have sub interface reach each other before OSPF can form the  relation :
check below example: make necessary IP changes to form OSPF peering and reachability.
http://www.orbit-computer-solutions.com/how-to-configure-frame-relay-subinterfaces/
DLC mapping also look below example :
https://ccieblog.co.uk/ospf/ospf-point-to-multipoint-network
BB
