Frame-Relay
fb_webuser
Level 6
Level 6
Why Frame-relay is called Non-Broadcast multiaccess?
Posted by WebUser Haroon David Peter
Because unlike etherrnet, it doesn't have capability where everyone can listen to the frames sent by one machine.
Smitesh
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
Just to add a little to Smitesh's post, frame-relay endpoints can all be on the same subnet, like generally found for multiple hosts on a shared Ethernet segment (i.e. both are multiaccess [or multipoint]), but broadcasts are not supported on frame relay (i.e. non-broadcast).
