Help RV110w not accepting bridge from router
Makem_Shorla
I have an old bt voyager router that i have set to bridge mode as i want it to function as modem only. Effectively as per this site:
http://www.puzbie.co.uk/forum/viewtopic.php?t=143
I can do this fine but when i conenct it to the rv110w it talks to it ok but cannot access the net. However if i connect the bt voyager to the wan just as a router (i.e. dont specifiy bridging) it works absolutely fine. Is there something i need to change on the rv110w?
Im sorry if this is basic but just starting out with these and need a little help..thanks
cadet alain
if you're bridging the modem then you need to do all the NAT and PPPoE as well as default routing on the router.
Regards.
Alain
Havent i done that already? sorry for being dumb
nm sorted thaks =]
