FRF.12 Fragmentation
massipace
IS FRF.12 fragmentation supported on frame-relay service interworking PVCs?
Is MLPP the only configuration allowed to configure fragmentation over SIW PVCs?
paolo bevilacqua
Please state your access and CIR speed and the reason why you think you need fragmentation.
I have slow speed link (128k) carring voice and data packets, to have the best performance I thought to configure MLPP with fragmentation and interleaving, I would like to know if I have the only option of MLPP or if I can configure FRF.12 alo on SIW PVCs.
TIA
FRF.11 and .12 are supported. Guide to config:
http://cisco.com/en/US/products/sw/iosswrel/ps1830/products_configuration_guide_book09186a00800870cb.html
But won't like work if the other end of the link is aal5snpa that has no support for fragmentation. So MLPPP is the only choice.
