From SW1 to R2 to R1 gateway
CyNiche
Hi all,
I'm having an issue getting cisco packet tracer to send packets from switch 1 to router 2 to router 1's gateway ip address. I've narrowed the problem down to ip routing within R2. From SW1, I can ping router 2 but cannot pass through R2 and ping R1. From R2, I can ping the gateway on R1 and ping SW1. I'm setting all ports up with static addresses.
My current config is SW1 interface g1/1/4 on vlan 10, Vlan 10 IP address is 192.159.0.2, routing to R2 interface g1/0 IP address 192.159.0.1, routing to R2 interface g0/0 IP address 192.100.0.2, routing to R1 interface g0/0 IP address 192.100.0.1, routing to R1 interface g9/0 IP address 192.168.0.1.
SW1 running config:
interface GigabitEthernet1/0/1
switchport access vlan 10
interface GigabitEthernet1/0/2
interface GigabitEthernet1/1/4
interface Vlan1
no ip address
shutdown
interface Vlan10
mac-address 0009.7ca2.9701
ip address 192.159.0.2 255.255.0.0
ip classless
ip route 192.168.0.0 255.255.0.0 Vlan10
ip route 192.100.0.0 255.255.0.0 Vlan10
R2 running config:
interface GigabitEthernet0/0
ip address 192.100.0.2 255.255.0.0
ip access-group 5 in
ip access-group 5 out
ip address 192.159.0.1 255.255.0.0
ip classless
ip route 192.168.0.0 255.255.0.0 GigabitEthernet0/0
ip route 192.100.0.0 255.255.0.0 GigabitEthernet1/0
ip route 192.100.0.0 255.255.0.0 192.100.0.0
ip flow-export version 9
access-list 5 permit any
R1 running config:
ip address 192.100.0.1 255.255.0.0
interface GigabitEthernet9/0
ip address 192.168.0.1 255.255.0.0
ip classless
ip route 192.168.0.0 255.255.0.0 192.159.0.0
ip route 192.100.0.0 255.255.0.0 192.168.0.0
Thanks for any help/insights
balaji.bandi
If your set up simply Only R1 R2 and SW, then they connected as below :
R1--R2--SW
then R2 is here for routing; enable ip routing (on all the devices)
R1 - remove all the routes and add below one route :
ip route 0.0.0.0 0.0.0.0 192.100.0.2
SW1 - same as above, remove all routes
ip route 0.0.0.0 0.0.0.0 192.159.0.1
R2.
ip routing enable
ip route 192.168.0.1 255.255.0.0 192.100.0.1
try and let us know; still issue post below output again
show run
Show IP interface brief
show ip route
show cdp neigh
Note: I have not looked at your access group applied on the interface, so until routing is fixed, remove that, test, and apply again once routing is working.
BB
@CyNiche
Your ACL looks weird. Remove the ACL and test. Or change to
Access-list 5 permit ip any any
You can also ZIP the file and attach here for further support
M02@rt37
Hello @CyNiche
On R2, the static route ip route 192.100.0.0 255.255.0.0 192.100.0.0 is problematic. The next-hop value (192.100.0.0) is a network address, not a valid next-hop IP or interface, which causes confusion in the routing process... This needs to be removed and replaced with a correct route pointing to R1's GigabitEthernet0/0 interface IP (192.100.0.1).
Additionally, the access list applied to both interfaces on R2 (ip access-group 5) is redundant since it permits all traffic (permit any) by default. These should be removed to avoid unnecessary processing or confusion.
On R1, there is a static route misconfiguration. The route ip route 192.100.0.0 255.255.0.0 192.168.0.0 points traffic for the 192.100.0.0/16 network to an incorrect next-hop network (192.168.0.0). This route needs to be corrected so that traffic destined for 192.159.0.0/16 is sent towards R2's GigabitEthernet0/0 interface (192.100.0.2).
Also; verify that SW1 is configured properly with VLAN 10 active and its IP address correctly set as 192.159.0.2/16. Once routing is fixed, ensure connectivity by pinging R2's interface (192.159.0.1), R1's interface (192.100.0.1), and finally R1's gateway (192.168.0.1) from SW1.
Best regards
