Full BGP Table into VRF on PE Routers
paolo_carbone
I have 2 Juniper MX5 routers which connect with 2 ME3600 in an MPLS ring. They all run as PE routers as I currenlty do not have a requirement for separate P routers.
I plan to have the full BGP internet table imported into an Internet VRF in each MX5 and then advertise a default route only to the internet VRF (route-target 65000:1000) in each ME3600 (only supports 20000 routes I believe).
The 2 MX5s need to exchange the full table so I was planning to use a different route-target (65000:1001) which they only import and export.
The question I have is relating to the VPNV4 tables in the ME3600s - if do "show ip bgp vpv4 all" then I see the 65000:1001 routes (just using a small number of test routes at the moment). These routes are not imported into the Internet VRF IPv4 table but I am concerned that the whole internet table is going to be showing int the VPNV4 table.
Is there anyone who could advise if this is a problem, and if so the best way to overcome the problem?
Many thanks
Paolo
I'm sorry, but I do not get anywhere with that link - what is it?!
