Full Global Routing Table on ASR1001-HX
mubashirimam
Can anyone confirm if ASR1001-HX support current Full BGP/Global Routing Table. Does a ram upgrade (from base 8GB to 16Gb) is required?
TIA
Kevin Groves
In order to run a full Border Gateway Protocol (BGP) table stably, more than 696MB might be needed. The recommended minimum in order to run SSO is 8GB total DRAM.
Check site: https://www.cisco.com/c/en/us/support/docs/routers/asr-1000-series-aggregation-services-routers/116233-technote-product-00.html
** Click (star) if you felt this was helpful.
Kevin Groves
If this was helpful, please indicate by clicking Helpful star. Thank you.
