02-19-2017 04:31 AM - edited 03-05-2019 08:03 AM
Hi Support Team,
I am getting following traps from my Cisco Router with ZBF configuration.
02-19-2017 16:00:14 Local7.Warning *.*.*.* 17099: 073718: Feb 19 16:00:13: %FW-4-TCP_OoO_SEG: Dropping TCP Segment: seq:-211084556 1492 bytes is out-of-order; expected seq:4083858056. Reason: TCP reassembly queue overflow - session 10.10.xx.xx:49236 to 13.107.4.50:80 on zone-pair ccp-zp-in-out class ccp-protocol-http
02-19-2017 16:00:12 Local7.Warning *.*.*.*.* 17098: 073717: Feb 19 16:00:11: %FW-4-TCP_OoO_SEG: Dropping TCP Segment: seq:-213998333 1492 bytes is out-of-order; expected seq:4080944279. Reason: TCP reassembly queue overflow - session 10.10.xx.xx :49236 to 13.107.4.50:80 on zone-pair ccp-zp-in-out class ccp-protocol-http
02-19-2017 16:00:10 Local7.Warning *.*.*.*.* 17097: 073716: Feb 19 16:00:09: %FW-4-TCP_OoO_SEG: Dropping TCP Segment: seq:-217027701 1492 bytes is out-of-order; expected seq:4077913459. Reason: TCP reassembly queue overflow - session 10.10.xx.xx :49236 to 13.107.4.50:80 on zone-pair ccp-zp-in-out class ccp-protocol-http
02-19-2017 16:00:08 Local7.Warning *.*.*.*.* 17096: 073715: Feb 19 16:00:07: %FW-4-TCP_OoO_SEG: Dropping TCP Segment: seq:-219744219 1492 bytes is out-of-order; expected seq:4075198393. Reason: TCP reassembly queue overflow - session 10.10.xx.xx:49236 to 13.107.4.50:80 on zone-pair ccp-zp-in-out class ccp-protocol-http
02-19-2017 16:00:07 Local7.Warning *.*.*.*.* 17095: 073714: Feb 19 16:00:06: %FW-4-TCP_OoO_SEG: Dropping TCP Segment: seq:-222295455 1492 bytes is out-of-order; expected seq:4072639897. Reason: TCP reassembly queue overflow - session 10.10.xx.xx:49236 to 13.107.4.50:80 on zone-pair ccp-zp-in-out class ccp-protocol-http
02-19-2017 16:00:05 Local7.Warning *.*.*.*.* 17094: 073713: Feb 19 16:00:04: %FW-4-TCP_OoO_SEG: Dropping TCP Segment: seq:-225164548 1492 bytes is out-of-order; expected seq:4069778064. Reason: TCP reassembly queue overflow - session 10.10.xx.xx:49236 to 13.107.4.50:80 on zone-pair ccp-zp-in-out class ccp-protocol-http
I tried with the following configuration:
ip inspect WAAS flush-timeout 10
But Problem is still.
Please guide a good method to resolve an issue.
Deepak Kumar
02-19-2017 05:58 AM
You could verify including this command line ip inspect tcp reassembly memory limit 4096. do you see any information executing the command line:
show ip inspect statistics
This link could be useful:
https://learningnetwork.cisco.com/thread/90952
02-19-2017 08:35 AM
The following output for "Sho
FO-R1#show
Interfaces configured for inspection 0
Session creations since subsystem startup or last reset 0
Current session counts (
Maxever session counts (
Last statistic reset never
Last session creation rate 0
Maxever session creation rate 0
Last half-open session total 0
TCP reassembly statistics
received 0 packets out-of-order; dropped 0
peak memory usage 0 KB; current usage: 0 KB
peak queue length 0
Please guide, why it showing no interface is configured for inspecting?
Please find attached file as the configuration file.
Deepak Kumar
02-19-2017 08:39 AM
Thanks, try to include this line and check if the messages stop
http://www.cisco.com/c/en/us/td/docs/ios/12_4t/12_4t11/ht_ooop.html
02-19-2017 09:04 PM
This solution is not working for me. Please guide me any other method.
Deepak Kumar
