FWSM high cpu utilization
We are experiencing some high cpu utlilization in our FWSM blade and i would like your opinion if this is normal. Sometimes the CPU touches 90% utilization.
FWSM/act# sh ver
FWSM Firewall Version 4.0(7)
Device Manager Version 6.2(3)F
Compiled on Tue 08-Sep-09 20:48 by fwsmbld
FWSM up 59 days 17 hours
failover cluster up 59 days 17 hours
Hardware:   WS-SVC-FWM-1, 1024 MB RAM, CPU Pentium III 1000 MHz
Flash STI Flash 8.0.0 @ 0xc321, 20MB
0: Int: GigabitEthernet0    : address is 0021.d80c.e300, irq 5
1: Int: GigabitEthernet1    : address is 0021.d80c.e300, irq 7
2: Int: EOBC0               : address is 0000.1100.0000, irq 11
Licensed features for this platform:
Maximum Interfaces          : 256
Inside Hosts                : Unlimited
Failover                    : Active/Active
VPN-DES                     : Enabled
VPN-3DES-AES                : Enabled
Cut-through Proxy           : Enabled
Guards                      : Enabled
URL Filtering               : Enabled
Security Contexts           : 2
GTP/GPRS                    : Disabled
BGP Stub                    : Disabled
Service Acceleration        : Disabled
VPN Peers                   : Unlimited
Serial Number:
FWSM/act#
FWSM/act# sh cpu usage
CPU utilization for 5 seconds = 34%; 1 minute: 39%; 5 minutes: 40%
HC-6500-FWSM/act# show processes cpu-hog
    MAXHOG             NUMHOG             LASTHOG             Process
       120                  7                110              fast_fixup
       200                  1                200              fover_rep
       200                  6                190              ssh
       160                  7                150              ssh
       160                  2                160              accept/http
       200                  1                200              qos_metric_daemon
FWSM/act# sh conn count
9137 in use, 41843 most used
FWSM/act# sh processes memory | e 0
Allocs   Allocated       Frees         Freed         Process
          (bytes)                      (bytes)
59715    5185868         83348         6187656       accept/http
29       174224          6             264           fover_thread
2        14              1             2             sqlnet
967      192942          967           192942        aaa
4        4297            1             13            ScpIncomingThread
6        5372            6             24972         Session Manager
6        44162           4             16648         route_process
9        396             9             396           fover_FSM_thread
26       17725           1             1281          ci/console
1336     88358           32            133184        websns_keepalive
4        8412            2             88            fover_ip
3252     26528           971           258742        tacplus_snd
8        352             8             352           fover_rx
8        352             8             352           lu_rx
On the MSFC:
WAN#sh module
Mod Ports Card Type                              Model
  1    6  Firewall Module                        WS-SVC-FWM-1
  2    6  Firewall Module                        WS-SVC-FWM-1
  5    2  Supervisor Engine 720 (Active)         WS-SUP720-3B
Mod MAC addresses                       Hw    Fw           Sw           Status
  1  001f.ca08.74c2 to 001f.ca08.74c9   4.3   7.2(1)       4.0(7)       Ok
  2  001f.6c88.6232 to 001f.6c88.6239   4.2   7.2(1)       4.0(7)       Ok
  5  0017.9444.d3bc to 0017.9444.d3bf   5.4   8.4(2)       12.2(33)SXI9 Ok
Mod  Sub-Module                  Model              Hw     Status
  3  Centralized Forwarding Card WS-F6700-CFC       4.1    Ok
  5  Policy Feature Card 3       WS-F6K-PFC3B       2.3    Ok
  5  MSFC3 Daughterboard         WS-SUP720          3.0    Ok
WAN#sh ver
Cisco IOS Software, s72033_rp Software (s72033_rp-ADVIPSERVICESK9_WAN-M), Version 12.2(33)SXI9, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Fri 24-Feb-12 21:38 by prod_rel_team
ROM: System Bootstrap, Version 12.2(17r)S4, RELEASE SOFTWARE (fc1)
WAN uptime is 8 weeks, 3 days, 17 hours, 32 minutes
Uptime for this control processor is 8 weeks, 3 days, 17 hours, 27 minutes
Time since GB-LON-HC-01-WAN switched to active is 8 weeks, 3 days, 17 hours, 26 minutes
System returned to ROM by reload (SP by reload)
System restarted at 19:40:39 BST Thu Aug 8 2013
System image file is "sup-bootdisk:s72033-advipservicesk9_wan-mz.122-33.SXI9.bin"
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C6509-E (R7000) processor (revision 1.3) with 458720K/65536K bytes of memory.
Processor board ID
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from s/w reset
6 Virtual Ethernet interfaces
120 Gigabit Ethernet interfaces
4 Ten Gigabit Ethernet interfaces
1917K bytes of non-volatile configuration memory.
8192K bytes of packet buffer memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
Any ideas?
TIA,
Nicos Nicolaides
TIA, Nicos Nicolaides
0 Replies 0
