Redundancy for VRF MGMT by using MPBGP ?
faradajay
Please find the Network Topology.
This is One Remote site and mamaged by Mgmt office.
All devices on remote site is accessed by MGMT Office. My organisation seek for Redundancy for Managing devices.
My administration is from MGW to R1. I am new to MPLS.
AS u can see in diagram, R1 have 3 VRF(Voice,Signal and MGMT).Currently i have primary link over whitch we are running MPBGP.
Traffic from these VRF goes to this primary link. Currently Secondary link is not connected.
Now my organisation proposed for  the  secondary  link  and they want that only traffic from VRF -- MGMT should go through MPLS RTR R2 (the secondary link ) , when the mgmt routes  not learned from MPLS  RTR R1 (Connected to the SP1 ).
BGP Neighbor ship is INTERNAL..(IBGP) with BOTH MPLS RTR.
Current  R1 config
BGP Config
router bgp 64513
  synchronization disable
  neighbor 10.36.150.1 remote-as 64513
  neighbor 10.36.150.1 activate
  neighbor 10.36.150.1 update-source loopback1
  address-family ipv4 vrf signalling
    redistribute connected
    redistribute static
  address-family ipv4 vrf voice
    redistribute static
  address-family ipv4 vrf OAM-T
    redistribute static
  address-family vpnv4
    neighbor 10.36.150.1 send-community
!<ospfv2>
router ospf 100
  interface gei-3/3
    network point-to-point
  network 10.36.150.49 0.0.0.0 area 0.0.0.0  --- loopback ip (Configured)
  network 10.36.149.60 0.0.0.3 area 0.0.0.0 ---- p2p ip bet R1 and MPLS R1.(Configured)
network 10.36.149.64 0.0.0.3 area 0.0.0.0 ---- p2p ip bet R1 and MPLS R2. ----------  (till now not configured as secondary link is not connected)
router-id 10.36.150.49
so what configuration need to done at R1  to achiev the redunancy for MGMT vrf ?
if possible please reply with sample configuration.
thanks in advance,
Ajay
blau grana
Level 7
Level 7
This is simple topology, there is not much to configure.
Just configure BGP session with MPLS R2 same way as you did with MPLS R1 router.
Best Regards
Please rate all helpful posts and close solved questions
Best Regards Please rate all helpful posts and close solved questions
