FXO card is not recognized
ud0508500
2811 router flash:c2800nm-advipservicesk9-mz.124-8d.bin
there are currently 3 VIC2-4FXO cards in slots 1-3. and 1 T1 card ..However the router is only recognizing the first 2. SH VER shows that there are 12 Voice FXO Interfaces.
Already tried moving cards around. No difference. Also moved the T1 card to last slot and tried the FXO cards in first 3 slots. Still does not work. Only ever sees the 1st 2 FXO cards no matter what slots they are in.
any ideas? greatly appreciate the help!
6 Replies 6
Can you please send the show diag output from the router. Could be an issue of DSPs.
-> Sushil
sure .... I see it... PVDM Slot 0:
8-channel (G.711) Voice/Fax PVDMII
8 channel- only going to support 8 of the 12..is that correct?
Slot 0:
C2811 Motherboard with 2FE and integrated VPN Port adapter, 2 ports
Port adapter is analyzed
Port adapter insertion time unknown
Onboard VPN : v2.2.0
EEPROM contents at hardware discovery:
PCB Serial Number : FOC12200YEC
Hardware Revision : 1.0
Top Assy. Part Number : 800-26920-04
Board Revision : A0
Deviation Number : 0
Fab Version : 04
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Processor type : 87
Hardware date code : 20080515
Chassis Serial Number : FTX1222A211
Chassis MAC Address : 001d.700b.fab8
MAC Address block size : 24
CLEI Code : COM7R00ARA
Product (FRU) Number : CISCO2811
Part Number : 73-10258-05
Version Identifier : V05
EEPROM format version 4
EEPROM contents (hex):
PVDM Slot 0:
8-channel (G.711) Voice/Fax PVDMII DSP SIMM PVDM daughter card
Hardware Revision : 4.0
Part Number : 73-8848-05
Board Revision : B0
Fab Version : 04
PCB Serial Number : FOC12133ESH
RMA History : 00
Processor type : 00
Product (FRU) Number : PVDM2-8
Version Identifier : V01
WIC Slot 0:
FT1 PMC4351
Hardware Revision : 1.2
PCB Serial Number : FOC12175KAY
Part Number : 73-8346-05
Board Revision : A0
RMA History : 00
Deviation Number : 0-0
Product (FRU) Number : WIC-1DSU-T1-V2
Top Assy. Part Number : 800-22193-03
CLEI Code : IPUIAPRRAA
Considering that you have the following modules -
VIC2-4FXO [3Nos.]
VWIC2-1MFT-T1/E1 [T1]
You'll need total 3 DSPs.
one PVDM2-32 + one PVDM2-8
I guess you'll have to add one more PVDM.
One PVDM2-8 is capable of supporting 8 FXO interfaces and this is what is happening with you. So you need additional DSPs for the other voice interfaces to be detected.
Hope this clarifies.
-> Sushil
Many thanks..greatly appreciate the help..thanks agin for your time
Hi, I have a question regarding your answer here. Is there any way you could run a VIC2-4FXO without any DSP's? Like possible in software?
Hi Peter,
I don't think that's possible. Hardware DSPs would be required for the card to work.
I am not saying that what you mentioned is not at all possible, i would rather say that its not implemented in such a way on cisco routers.
-> Sushil
