G3 GSM Module for 1800 Series Router
premaximus
Hello Experts,
I am looking for a solution where I can connect local LAN user using WIFI and connect then Using 3G GSM connection to the internet.
so I need Wifi (WLAN) 3G GSM (WWAN) so what you will suggest me to slect as a router + Modules which can best fit in my requirment..
Does HWIC-3G-GSM Support normal mobile "SIM CARD" to connect to the service provider.
Its a little urgent..
Shahid
paolo bevilacqua
Yes.
