Gateway cannot be reached through port Ethernet1/1 named “outside
Derek1993
Hello One More Time Community.
I have a problem with data interface and cann't resolve it: I have an error like this Gateway cannot be reached through port Ethernet1/1 named “outside". My configuratiion:
> show ip
System IP Addresses:
Interface                Name                   IP address      Subnet mask     Method
Ethernet1/1              outside                10.10.61.77      255.255.255.0   DHCP
Ethernet1/2              inside_1_2    192.168.1.1    255.255.255.0   manual
Ethernet1/3              inside_1_3 192.168.2.1    255.255.255.0   manual
Ethernet1/4              inside_1_4 192.168.3.1    255.255.255.0   manual
Ethernet1/5              inside_1_5 192.168.4.1    255.255.255.0   manual
Management1/1            diagnostic             unassigned      unassigned      DHCP
BVI1                     bvi                    192.168.77.1    255.255.255.0   manual
show network
Hostname                  : Firewall
Domains                   : google.com
DNS Servers               : 8.8.8.8
                            8.8.4.4
DNS from router           : disabled
Management port           : 8305
IPv4 Default route
  Gateway                 : 192.168.45.1
  Netmask                 : 0.0.0.0
==================[ management0 ]===================
Admin State               : enabled
Admin Speed               : 1gbps
Operation Speed           : indeterminate
Link                      : link-down
Channels                  : Management & Events
Mode                      : Non-Autonegotiation
MDI/MDIX                  : Auto/MDIX
MTU                       : 1500
MAC Address               : 40:06:D5:85:FF:80
----------------------[ IPv4 ]----------------------
Configuration             : Manual
Address                   : 192.168.45.45
Netmask                   : 255.255.255.0
----------------------[ IPv6 ]----------------------
Configuration             : Disabled
Plz Help Me !
13 Replies 13
Hi  @Derek1993
Where do you see this error? On the firewall ?
you getway seems to be  192.168.45.1 and you outsinde is 10.10.61.77. You seems not have any interface on the network 192.168.45.0
@Flavio Miranda Ok and What kind of configuration I must to provide for Management Interface ? Help
Derek1993
@Flavio Miranda  Hi added pictures of my configuration:
I believe the problem can be related to this config.  As you are checking "Use the Data interface as the Gateway" it is trying to send the data through the outside interface.
Yes I am use this configuration beacause I haven't ANY  seperate network or cabel for management interface: I want to use only data interface, I don't have another cabel for Management interface!
I believe this is not a problem but you need to make sure you have recheability through  outside to the gateway. If the outside interface is connected to ISP, for example, this could be a problem for you.
Yes My oitside interface Connected to my ISP, I don't have any routers before my FP 1120 ? What I must to do in this situation ?
Try to select the option "Use unique gateway for the management interface" and select one interface you have connectivity with the manager.
Ok, BUT There is no any selection of interface, where I must to select interface, and One More I configure my FP vid FDM not FMC!
In this situation what I must to select ?
Change from DHCP to static and add the IP address.  You might have connectivity through another interface. Try the BVI interface.  Use like 192.168.77.2  255.255.255.0 and use the BVI as gateway 192.168.77.1
Derek1993
I am change, BUT any result, still the same issues. One more whe I set management interface use this command configure network ipv4 dhcp-dp-route and set Configuration for Management interface to DHCP, I can run ping system 8.8.8.8 and All is Work, BUT I can ping system www.cicso.com
Here is output from CMD
===============[ System Information ]===============
Hostname                  : Firewall
DNS Servers               : 1.1.1.1
                            1.0.0.1
Admin Speed               : 1gbps
Link                      : link-down
MTU                       : 1500
Configuration             : DHCP
===============[ Proxy Information ]================
State                     : Disabled
Authentication            : Disabled
ping system 8.8.8.8
> ping system 8.8.8.8
PING 8.8.8.8 (8.8.8.8) 56(84) bytes of data.
64 bytes from 8.8.8.8: icmp_seq=1 ttl=121 time=16.1 ms
64 bytes from 8.8.8.8: icmp_seq=2 ttl=121 time=15.3 ms
64 bytes from 8.8.8.8: icmp_seq=3 ttl=121 time=15.4 ms
64 bytes from 8.8.8.8: icmp_seq=4 ttl=121 time=15.9 ms
64 bytes from 8.8.8.8: icmp_seq=5 ttl=121 time=15.10 ms
^C
--- 8.8.8.8 ping statistics ---
5 packets transmitted, 5 received, 0% packet loss, time 7ms
ping system google.com
ping: google.com: Temporary failure in name resolution
You are missing DNS.
PPPoE on FMC - Cisco Community
for the OUTside since it learn IP from DHCP you need to enable route for that interface
this will make FPR have automatic default route toward ISP
