Gateway to Gateway VPN waiting to connect help!
allinarush
I have 4 locations that are utilizing gateway to gateway connections. 3 locations have the Cisco RV325 Wan VPN Routers and one has an ASA. Under the VPN Summary tab the 3 VPN connections were all connected at one time and recently the status went to waiting for connection. Nothing has changed that could have caused this that im aware of. I tried switching them all to aggressive mode and back but it still goes back to "Waiting to connect".
There are 4 sites, Office 1, Office 2, Office 3, and Office 4.
All of the offices are connected to each other except office 2. Office 2 is waiting connection to all of them.
I've compared the settings side by side and they are all the same. HELP!
allinarush
Updated firmware, deleted connections, and reconnected successfully.
Thanks for posting back to the forum and letting us know that you have solved the problem. +5 for that. My guess is that the update firmware might have been the important part of it.
Rick
Rick
