GBIC in 6509 and GBIC for 7206/ASR 1002
network_user
Beginner
Beginner
We have a 6509 Sup2 at our ISP edge with fiber connection to ISP. I am planning on replacing the 6509 either with 7206VXR-GE2 or ASR 1002.
How do I find out what GBIC is installed on my Sup2 right now where Fiber cable is connected?
What GBIC/SFP will be compatible for this on 7206VXR or ASR1002?
If I use SFP do I need to change the cable connector?
Thank you.
5 Replies 5
vilaxmi
Hii,
To find out which type of GBIC connector is present in your SUP2 right now, you can issue:-
show inventory
show int x/y trasceiver detail
Also,once you know the model of GBIC , try to lookup CCO and find compatiblity matrix for 7200 hw and sw and you will be all set..!
Vijaya
Leo Laohoo
VIP Community Legend VIP Community Legend
Cisco Gigabit Ethernet Transceiver Modules Compatibility Matrix
http://www.cisco.com/en/US/docs/interfaces_modules/transceiver_modules/compatibility/matrix/OL_6981.html
Hello Vijaya,
Thanks for your response. Show int x/y transceiver de is not available on my 6509 switch. And when I do show inventory I get below output:
sh inventory
NAME: "Chassis", DESCR: "Cisco Systems WS-C6509 9 slot switch"
PID: WS-C6509          , VID:    , SN: SCA043600XN
NAME: "Clock 1", DESCR: "WS-C6000-CL 1"
PID: WS-C6000-CL       , VID:    , SN: SMT04357945
NAME: "Clock 2", DESCR: "WS-C6000-CL 2"
PID: WS-C6000-CL       , VID:    , SN: SMT04357951
NAME: "VTT 1", DESCR: "WS-C6000-VTT 1"
PID: WS-C6000-VTT      , VID:    , SN: SMT04349784
NAME: "VTT 2", DESCR: "WS-C6000-VTT 2"
PID: WS-C6000-VTT      , VID:    , SN: SMT04373913
NAME: "VTT 3", DESCR: "WS-C6000-VTT 3"
PID: WS-C6000-VTT      , VID:    , SN: SMT04366902
NAME: "1", DESCR: "1000BaseX Supervisor 2 port WS-X6K-SUP2-2GE Rev. 4.3"
PID: WS-X6K-SUP2-2GE   , VID:    , SN: SAL0743NWUN
NAME: "submodule 1/1", DESCR: "L3 Switching Engine II"
PID: WS-F6K-PFC2       , VID:    , SN: SAL0744NXRD
NAME: "15", DESCR: "Router Switch feature Card"
PID: WS-F6K-MSFC2      , VID:    , SN: SAL0743NM2G
NAME: "3", DESCR: "10/100BaseTX Ethernet 48 port WS-X6348-RJ-45 Rev. 1.1"
PID: WS-X6348-RJ-45    , VID:    , SN: SAD04310607
NAME: "4", DESCR: "10/100BaseTX Ethernet 48 port WS-X6348-RJ-45 Rev. 2.3"
PID: WS-X6348-RJ-45    , VID:    , SN: SAL044622TY
NAME: "5", DESCR: "10/100BaseTX Ethernet 48 port WS-X6348-RJ-45 Rev. 2.3"
PID: WS-X6348-RJ-45    , VID:    , SN: SAL04451NS7
NAME: "7", DESCR: "1000BaseX Ethernet 8 port WS-X6408-GBIC Rev. 2.4"
PID: WS-X6408-GBIC     , VID:    , SN: SAD0412023C
NAME: "8", DESCR: "Intrusion Detection Mod 0 port WS-X6381-IDS Rev. 0.0"
PID: WS-X6381-IDS      , VID:    , SN:
NAME: "PS 1", DESCR: "1300 watt supply AC"
PID: WS-CAC-1300W      , VID:    , SN: SON04320848
NAME: "PS 2", DESCR: "1300 watt supply AC"
PID: WS-CAC-1300W      , VID:    , SN: SON04331759
NAME: "Fan 1", DESCR: "WS-C6K-9SLOT-FAN 1"
PID: WS-C6K-9SLOT-FAN  , VID:    , SN:
However it does not show me what GBIC is installed on my Sup2 (Port 1 and Port2)...
They are different.  You can not use the GBIC from your sup 2 and put it in an ASR.  Sup 2 uses regular GBIC with SC type connector and ASR uses SFP with LC type connector. So, you need to get 1Gig SFP for your ASR.
Reza
Leo Laohoo
The following SFP are supported on the ASR:
SFP-GE-T
SFP-GE-S
SFP-GE-L
SFP-GE-Z
CWDM SFP
DWDM SFP
Recognize Your Peers
