GGSN ASR5000 ¨ip address alloc-method´´
karim.soboh1
Hi Dear,
Kindly,
we need to define a fix IP address (static) for each IMSI number on a specific APN. and the RADIUS server will do the job to assign
a fixed IP address for all IMSI numbers every time doing a PDP context, so, in that case, which of below option should I choose
in the IP allocation method under APN configuration:
allow-user-specified
Enables support for PDP contexts requesting the use of specific (static) addresses. Default: Enabled
local
Configures the APN to allocate IP addresses from a pool configured in the destination context on the system.Default: Enabled
Thanks in advance.
Br\\Karim
0 Replies 0
