Gigabit Ethernet Loopback Plug for 3845 Router Gigabit Interface
Lou_Valle
I have an Ethernet Loopback Plug (4 Pairs) made and trying to test the Gigabit Interface on a 3845 Router with a fail result. The interface will show up/up only if I set the interface to 100M/Full Duplex when I plug-in the Ethernet Loopback Plug (4 Pairs). I don't see this Gigabit Interface @ 3845 router has any option to set it to internal or external loopback. Any help will be appreciated, thx.
Jeff Van Houten
Level 5
Level 5
Take a look at
http://www.kozio.com/view_files/Kozio_TN_GigabitEthernetLoopback.pdf
Hi, Jeff: Thanks for your PDF.
The problem is how to disable the NEXT canceller on 3845? Thanks again.
Lou.
