please help with best solution, multihomed internet without BGP
carl_townshend
Hello all
Canm anyone help, I have 2 internet connections from 2 different providers, these 2 routers sit infront of my firewall.
At the moment only 1 router is used, the other is doing nothing.
The only thing we have is a Site to Site VPN which comes in over one of these links
what is the best way to get these links running, 1 primary and the other standby so they failover automatically.
cheers
Carl
7 Replies 7
cadet alain
use reliable static routing with enhanced object tracking: http://www.cisco.com/en/US/docs/ios/12_3/12_3x/12_3xe/feature/guide/dbackupx.html
Regards.
Alain
The problem is these 2 routers sit infront of my checkpoint firewall so the firewall cant really do alot, what do you suggest ?
should I join the 2 different ISP routers with HSRP ?
What do you mean in front? these are not the border routers connected to ISPs?
Regards.
Alain
I mean a i have a router from ISP 1, ISP 2, these then connect to my firewall.
my firewall currently has a default route to ISP 1, all nat is done on the firewall.
how can i get ISP 2 to work in a failover scenario ?
cheers
Use both public IP on the router then add an interconnect /30 between router&firewall: 10.0.0.0/30.
You will do NAT on the router and traffic-control (firewall) on the Checkpoint; this mean you have to redo your existing configuration on the firewall.
Another solution add an interconnect /30 between checkpoint dmz port and router and whenever your primary ISP fails, checkpoint will use a failover route through your router. In this case you can keep your existing configuration.
would I have to do multiple nat statements on the firewall for this ?
would this work ok as a failover if I put a metric on one of the default routes on the firewall ?
Jeff Van Houten
Level 5
Level 5
Checkpoint has a load balancing option for just this scenario.
