gigabitethernet0/0 is up while the line protocol is down (disabled) .
krishnapriyaas
I am using Cisco packet tracer.I connected two routers using a crossover cable.My interface gigabitethernet0/0 is up while the line protocol is down (disabled) .
I used the no shutdown option.I also changed the speed and the duplex to auto mode.Still the line protocol is down.How to correct this?
Router#sh int
GigabitEthernet0/0 is up, line protocol is down (disabled)
  Hardware is CN Gigabit Ethernet, address is 00e0.8fc7.5901 (bia 00e0.8fc7.5901)
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, media type is RJ45
  output flow-control is unsupported, input flow-control is unsupported
  ARP type: ARPA, ARP Timeout 04:00:00,
  Last input 00:00:08, output 00:00:05, output hang never
  Input queue: 0/75/0 (size/max/drops); Total output drops: 0
  Queueing strategy: fifo
  Output queue :0/40 (size/max)
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     0 watchdog, 1017 multicast, 0 pause input
     0 packets output, 0 bytes, 0 underruns
Danny Morris
Can you post your configuration for these 2 interfaces?
Have you added any IP address information to these interfaces? These are layer 3 interfaces and will not show as "up/up" without an IP address.
CSCO12302959
Your router does not get signal from other end make sure that you configure the IP address on the other end to be on the same network with the your router for example 192.168.1.0/30, and also check clocking,DCE show be on the service provider site and DTE on the client side
