GLC-FE-100EX compatibility with ISR4451
bharat1234
following link says GLC-FE-100EX is not compatible with ISR4451 whereas it is accessible under ISR4451 in CCW, Please advise
https://www.cisco.com/c/en/us/td/docs/interfaces_modules/transceiver_modules/compatibility/matrix/100MB_Tx_Matrix.html
Julio E. Moisa
As you mentioned I see it on the CCW and if it is included on the SFPs for On-Board GE Ports you can use it because it is part of its configuration, probably the website is not updated.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Julio E. Moisa
Leo Laohoo
According to THIS, GLC-FX-100EX is supported with 3.10.X.
