ISR435 and 2 10G modules
jahansouz
Hello  There
Can cisco  ISR4351  support Two  SM-X-4X1G-1X10G (10G)?
how many DRAM and License is needed?
TNX
Dennis Mink
https://www.cisco.com/c/en/us/products/collateral/routers/4000-series-integrated-services-routers-isr/datasheet-c78-730527.html
no licenses needed to run hardware
Please remember to rate useful posts, by clicking on the stars below.
Philip D'Ath
Note that the 4351 is limited to 1Gb/s of performance. You may want to consider buying the licence to increase the throughput to 2Gb/s.
Also note that although you might be able to plug in 2 x 10Gbe circuits - you will only be able to use a tiny percentage of their capacity due to the performance limits.
