GNS3 & dyanamips
Rupesh Kashyap
Hi, I have installed GNS3 and binded IOS. Dyanamips coniguration is OK. Whenever I am adding router in the topology,the error is -"Time Out Communicating with Dynamips server Local host.' Please help.
Is the Dynamips server running?
Go to the GNS3 install folder :
suppose you installed GNS3 in
C:\program Files\GNS3
and then execute the file "dynamips-start.cmd"
it should say Hypervisor TCP control server started
Justin Brenton
Level 4
Level 4
Hi rupesh_kashyap,
Other then the previous post which would step you in the right direction. Have you installed the latest version of GNS3?
Also the GNS3 forums would probably provide you better support on this issue.
I know with the latest version of GNS3 you do NOT have to start the server manually.
Hope this helps, Please rate my post below if so
Justin
milan.kulik
Level 10
Level 10
I was in simailar trouble and
1. I was getting a message from my Personal FW to block GNS3 connections to Dynamips on the local machine.
So I permitted that connetions.
2. I also went to Edit -> Preferences -> Dynamips, checked the path to dynamips-wxp.exe
and ran Test.
After Dynamips successfully started result, everything worked fine.
BR,
Milan
