got error message from inserting EHWIC-4ESG in 3925
mishao
                   hi,
                       could everyone see the message "%ESWGE_ERR-3-NIOSII_UP_FAIL: NIOSII fails on 0/3/0 ehwic slot" in 3925 ?
                    we install a new module EHWIC-4ESG in 3925 with ios 15.2.2(T1). 3925 couldn't find the module but got error message above.
Leo Laohoo
I think you need to reboot the router because OIR is not supported.
vankom
Same error: %ESWGE_ERR-3-NIOSII_UP_FAIL: NIOSII fails on 0/0/0 ehwic slot
Module is already inserted, error message after reload Cisco 2900. IOS 15.1(4)M6.
This can be seen when either card or HWIC chassis slot are faulty. I suggest to check the card in another router to verify if the module is faulty.
Kind Regards,
Ivan Shirshin
**Please grade this post if you find it useful.
Kind Regards,
Ivan
Hi!
Have you been able to solve this issue?
BR,
Miguel
