GPS NMEA Streaming with NIM-LTEA-EA on ISR4000
emuman100
Has anyone been able to figure out exactly how to use the NMEA streaming over IP option using the NIM-LTEA-EA on an ISR4000? I cannot figure it out at all. The configuration here says you specify a source IP, destination IP, and port:
lte gps nmea {ip | udp [source address][destination address][destination port] }
or
lte gps nmea
I'm hoping that I can simply set up something that can telnet to on the router on a specific port and I get the NMEA sentences. On the ISR G2 series with the 4G EHWICs, a line was set up that you can telnet into on the appropriate port. Is that how this works or does it work differently?
I can't find any documentation on this and I'm curious if anyone was able to figure this out.
Thanks.
0 Replies 0
