GRE over Frame relay
nagesh
hi
we have a requirement where in we need to run GRE tunnel over a frame-relay point-to-point to link i need questions to the following.
1.Can we configure GRE tunnel over a Frame-relay point-to-point link
2.What is the minimum router requirement
3.Sample configuration of GRE
Thanks in advance.
/\/agesh.
Richard Burts
Nagesh
I have not done this exactly as you describe so I can not speak from experience. But it should be easy to do.
I believe that any router that supports point to point Frame Relay will also support GRE tunnels. they have been supported in IOS for a very long time.
The configuration would look something like this (details would obviously depend on your situation):
interface tunnel 1
ip address
tunnel source serial1/1.200
tunnel destination
Rick
Rick
thnx rick
will check this up and post the results
