GRE tunnel as OSPF neighbor
laviel
Hi all,
I have a setup in which I've got two routers (router A and router B) connected indirectly through several other routers and between these two routers theres a functioning GRE tunnel whose IP address on each side is based on the loopback address (10.11.21.5 and 10.11.21.6 respectively). In addition there's an MPLS-TE tunnel headed from router B to router A, also based on these loopback addresses.
Point-to-Point OSPF is running between each of the routers and its adjacent core routers (see diagram below). All OSPF neighbors are up correctly, but the thing is that there's an OSPF adjacency over the GRE tunnel as well and I'm not sure how to get rid of it. Here's the diagram:
Here is the output of show ip ospf neighbor from both routers:
Router A:
RouterA1#show ip ospf neighbor
Neighbor ID     Pri   State           Dead Time   Address         Interface
10.11.21.6        0   FULL/  -        00:00:32    10.11.21.6      Tunnel501
10.11.21.4        0   FULL/  -        00:00:39    10.11.11.45     GigabitEthernet2/4
10.11.21.4        0   FULL/  -        00:00:39    10.11.11.41     GigabitEthernet2/3
10.11.21.3        0   FULL/  -        00:00:31    10.11.11.29     GigabitEthernet5/1/1
10.10.21.2        0   FULL/  -        00:00:38    10.11.11.25     GigabitEthernet5/1/0
RouterA#
Router B:
RouterB#show ip ospf neighbor
10.11.21.5        0   FULL/  -        00:00:39    10.11.21.5      Tunnel501
10.11.21.3        0   FULL/  -        00:00:34    10.11.11.37     GigabitEthernet6/0/1
10.11.21.1        0   FULL/  -        00:00:38    10.11.11.33     GigabitEthernet6/0/0
RouterB#
Here are the GRE tunnel configurations, plus the loopback configurations on the two routers:
Router A:
interface Tunnel501
description ### GRE Tunnel to NPE-7609-RAN1 ###
ip unnumbered Loopback0
no ip route-cache
keepalive 60 5
tunnel source 10.11.11.26
tunnel destination 10.11.11.34
tunnel key 30
tunnel checksum
end
interface Loopback0
ip address 10.11.21.5 255.255.255.255
end
Router B:
interface Tunnel501
description ### GRE Tunnel to NPE-7606-RAN1 ###
no ip route-cache
keepalive 60 5
tunnel source 10.11.11.34
tunnel destination 10.11.11.26
tunnel key 30
tunnel checksum
end
interface Loopback0
ip address 10.11.21.6 255.255.255.255
end
Here's the show run | s router ospf section from both routers:
Router A:
RouterA#show run | s router ospf
router ospf 65200
router-id 10.11.21.5
network 10.11.11.24 0.0.0.3 area 0
network 10.11.11.28 0.0.0.3 area 0
network 10.11.11.40 0.0.0.3 area 0
network 10.11.11.44 0.0.0.3 area 0
network 10.11.21.5 0.0.0.0 area 0
bfd all-interfaces
mpls traffic-eng router-id Loopback0
mpls traffic-eng area 0
Router B:
RouterB#show run | s router ospf
router ospf 65200
router-id 10.11.21.6
network 10.11.11.32 0.0.0.3 area 0
network 10.11.11.36 0.0.0.3 area 0
network 10.11.21.6 0.0.0.0 area 0
bfd all-interfaces
If there are any other missing details, pleaes let me know.
Thanks in advance,
Lior
Peter Paluch
Hello Lior,
Your issue is caused by the fact that your Tunnel interfaces are configured as IP Unnumbered interfaces, using the IP address from the loopbacks, and you have added the loopback addresses into OSPF. As a result, OSPF runs on all interfaces that share the IP addresses of the loobacks - in your case, the tunnels. This is the general behavior of IP Unnumbered - as soon as you add the "master" interface to a routing protocol, it will run on all interfaces that share the IP address of the "master" interface.
There are two ways of getting rid of the OSPF adjacency through the GRE tunnels - either configure the tunnels with their own unique IP address that is not added to OSPF, or declare them as passive interfaces in the OSPF configuration.
Best regards,
Peter
Peter Paluch
Hello Lior,
Best regards,
Peter
Hi Peter,
Thanks a lot for your answer, I'll give the passive interface a try
Lior
