GRE over WAN
RonaldNutter
I am trying to setup a GRE tunnel using loopback addresses on two different routers.   For security reasons, I dont want to advertise that ip addresses of the tunnel interfaces on the network.  I can ping the ip address of both the local and remote loopback addresses, the GRE tunnel wont go up/up.
Here is the config of R1 (local router)
interface Loopback0
ip address 10.1.1.1 255.255.255.255
interface Tunnel0
ip address 10.0.1.1 255.255.255.0
tunnel source Loopback0
tunnel destination 3.3.3.3
interface FastEthernet0/0
ip address 10.1.2.1 255.255.255.0
duplex auto
speed auto
interface Ethernet1/0
no ip address
shutdown
half-duplex
router eigrp 1
network 10.1.1.1 0.0.0.0
network 10.1.2.0 0.0.0.255
no auto-summary
no ip http server
ip forward-protocol nd
ip route 10.0.3.3 255.255.255.255 10.2.3.3
There is an intermediate router R2 between R1 and R2 to simulate for an updates PE router that we will be going through.  Thought this was possible but not having any luck.
Edison Ortiz
Please post your routing table and configuration from the 3 devices.
Ronald
The question from Edison is an excellent starting point. To add a bit to his question, the main requirement for a standard GRE tunnel to come up/up is that the router must have a valid route to the tunnel destination in the routing table. There are no static routes for the 3.3.3.3 destination so the router will need to have learned the route to 3.3.3.3 via EIGRP. And Edison's request to post the routing table is an excellent way to determine whether this requirement has been met.
Rick
Rick
Tomas Fidler
I'm wondering if tunnel destination 3.3.3.3 is not just typo...
i think static route:
is somehow a clue.
If you can ping from one loopback to other one using command like:
from R3: ping 10.1.1.1 source loopback 0
you should look on that "tunnel destination"!!
