GRE tunnel IP's dont ping even though Tunnel source and destination are reachable
starbearer
Hello All,
I'm trying to setup OSPF over internet IPSEC VPN's. The IPSEC is established without any problems. The GRE tunnel however, doesnt ping from one side to the other. Here are the configs
R1
interface Tunnel150
  bandwidth 12000
ip address 172.27.150.161 255.255.255.252
ip ospf network broadcast
ip ospf cost 150
ip ospf mtu-ignore
tunnel source 10.200.55.2
tunnel mode ipip
tunnel destination 10.150.200.2
end
R1#ping 10.150.200.2 so 10.200.55.2
Sending 5, 100-byte ICMP Echos to 10.150.200.2, timeout is 2 seconds:
Packet sent with a source address of 10.200.55.2
Success rate is 100 percent (5/5), round-trip min/avg/max = 160/160/160 ms
R1#ping 172.27.150.162 so 172.27.150.161
Sending 5, 100-byte ICMP Echos to 172.27.150.162, timeout is 2 seconds:
Packet sent with a source address of 172.27.150.161
Success rate is 0 percent (0/5)
Here it is from R2:
interface Tunnel55
bandwidth 12000
ip address 172.27.150.162 255.255.255.252
ip ospf cost 150
tunnel source 10.150.200.2
tunnel mode ipip
tunnel destination 10.200.55.2
end
R2#ping 10.200.55.2 so 10.150.200.4 (10.150.200.2 is the virtual IP. Tried setting the physical IP on the tunnel too, without luck)
Sending 5, 100-byte ICMP Echos to 10.200.55.2, timeout is 2 seconds:
Packet sent with a source address of 10.150.200.4
Success rate is 100 percent (5/5), round-trip min/avg/max = 158/158/160 ms
R2#ping 172.27.150.161 so 172.27.150.162
Sending 5, 100-byte ICMP Echos to 172.27.150.161, timeout is 2 seconds:
Packet sent with a source address of 172.27.150.162
Because of this the OSPF never comes up
10.150.200.2      1   INIT/DROTHER    00:00:39    172.27.150.162  Tunnel150
What could be wrong? I'm at my wits end and my whole team has mostly given up on this. Please help.
Richard Burts
Your description indicates that you are trying to do IPSec with GRE tunnels. I see that the tunnel mode is ipip and not GRE. I wonder what would happen if you made the tunnel into GRE.
It is also possible that the problem has to do with how IPSec was configured or with something configured on the physical interface such as access list. Perhaps you can post a more complete version of the config and we might be able to give you a better answer.
Rick
Rick
Hi, Thanks for replying back.
The topology is as below:
R1 ---------------------------------- ASA1 ----- Internet ------ ASA2---------------- R2
10.200.55.2        10.150.200.2
The 10.200.55.2 is the IP address of the R1 interface connected to the ASA1
Similarly, 10.150.200.2 is the IP address of the R2 interface connected to the ASA2
ASA1 to ASA2 have the IPSEC tunnel. R1 to R2 is the GRE. I can ping from 10.200.55.2 to 10.150.200.2 only because the IPSEC is up.
I changed the tunnel mode to GRE but its still the same. I changed the tunnel IP's to .9 and .10
R1
interface Tunnel150
bandwidth 12000
ip address 172.27.150.9 255.255.255.252
ip mtu 1400
ip ospf cost 150
end
R2
interface Tunnel55
bandwidth 12000
ip address 172.27.150.10 255.255.255.252
ip mtu 1400
ip ospf cost 150
end
R1#ping 172.27.150.10 so 172.27.150.9
Sending 5, 100-byte ICMP Echos to 172.27.150.10, timeout is 2 seconds:
Packet sent with a source address of 172.27.150.9
172.27.150.9 cant ping 172.27.150.10 and the OSPF never comes up
Whats interesting is that on R1, I can see R2 in the OSPF neighbors
Neighbor ID     Pri   State           Dead Time   Address         Interface
10.150.200.1      1   INIT/DROTHER    00:00:39    172.27.150.162   Tunnel150
But nothing about R2 in R1. So that means that R2's Hello's are reaching R1 but not the other way round.
Also, regarding your ACL question, there are no ACL's on the R1 router
R1#sh access-l
Standard IP access list 23
    10 permit 10.10.10.0, wildcard bits 0.0.0.7
Standard IP access list BGP_filter_in
Standard IP access list BGP_filter_out
ACL 23 is the default one which the router ships with and is not being used on any interface. I can remove that if needed.
Can you post output from both routers:
sh ip route 172.27.150.8
And IPSec configuration on both ASAs.
Hope it will help.
Best regards,
Abzal
Best regards,
Abzal
