Troubleshooting NAT - not allowing RDP session
aducey01
I'm using a 2601 router and it's not letting me rdp to my desktop.
ip nat inside source list natpool interface FastEthernet0/0 overload
ip nat inside source static tcp 10.22.22.24 3389 176.x.x.x 3389 extendable
ip access-list extended natpool
deny   ip 10.22.22.0 0.0.0.255 10.0.0.0 0.255.255.255
deny   ip 10.22.22.0 0.0.0.255 136.200.0.0 0.0.255.255
permit ip any any
R1#show ip nat translations
Pro Inside global         Inside local          Outside local         Outside global
tcp 176.x.x.x:3389   10.22.22.24:3389      ---                   ---
thanks!
6 Replies 6
mfurnival
Level 4
Level 4
Initiate an RDP connection to the outside interface address and do a "debug ip nat" and post the results here.
looks like NAT's working, no?
Jul 18 12:10:20.033: NAT: expiring 176.x.x.x (10.22.22.100) udp 46749 (46749)
*Jul 18 12:10:20.073: NAT*: s=136.200.176.191, d=176.x.x.x->10.22.22.24 [32284]
*Jul 18 12:10:20.489: NAT: s=10.22.22.100->176.x.x.x, d=66.60.130.2 [39379]
*Jul 18 12:10:20.505: NAT: s=66.60.130.2, d=176.x.x.x->10.22.22.100 [0]
*Jul 18 12:10:21.057: NAT: expiring 176.x.x.x (10.22.22.100) udp 56994 (56994)
have you got any ACL on the inside interface or zome IOS firewall configuration that could block the return traffic ?
Hve you tested from inside that the RDP port is accessible first ? if yes then can you post your sanitized config.
Alain
I can RDP in the other direction...
What do you mean by that? you can RDP to an outside device from inside? But that does n't mean that tcp sourced from port 3389 is permitted from inside, it means that tcp to dst port 3389 is not denied.
Alain
sorry guys...this was a case of kaspersky blocking RDP...fixed now, thanks!
