GRE tunnel issue
Earthwarder
Greetings,
I am trying to get gre tunnel working and eventually with ipsec. My problem is that I cannot get the gre tunnel working. I believe my configurations to be correct. I have EIRGP neighbor adjacency among the other prerequisites configured and I am a little stumped. I think it might be a fairly obvious solution, but I am just not seeing it. Please give me a hand and if I missed some information here to post, let me know. I am not certain if google drive links work here since the attachments do not for .pkt's but here is the packet tracer that I'm referring too
Many thanks in advance!
note: both routers are ISR4321's
Router 1
version 15.4
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname isp
no ip cef
no ipv6 cef
spanning-tree mode pvst
interface Loopback0
 ip address 192.168.7.1 255.255.255.0
interface Tunnel1
 ip address 100.100.100.2 255.255.255.252
 mtu 1476
 tunnel source Serial0/2/1
 tunnel destination 2.2.2.2
interface GigabitEthernet0/0/0
 no ip address
 duplex auto
 speed auto
 shutdown
interface GigabitEthernet0/0/1
 no ip address
 duplex auto
 speed auto
 shutdown
interface Serial0/1/0
 ip address 192.168.4.1 255.255.255.252
 ip nat inside
interface Serial0/1/1
 ip address 192.168.4.5 255.255.255.252
 ip nat inside
interface Serial0/2/0
 ip address 192.168.4.9 255.255.255.252
interface Serial0/2/1
 ip address 192.168.4.13 255.255.255.252
interface Vlan1
 no ip address
 shutdown
router eigrp 1
 network 192.168.4.0
 network 192.168.5.0
 network 192.168.3.0
 network 192.168.2.0
 network 192.168.1.0
 network 100.0.0.0
ip nat pool INTERNET 211.1.1.1 211.1.1.30 netmask 255.255.255.224
ip nat inside source list 10 pool INTERNET overload
ip classless
ip route 192.168.3.0 255.255.255.0 192.168.4.6
ip route 192.168.1.0 255.255.255.0 200.1.1.2
ip route 192.168.1.0 255.255.255.0 192.168.4.10
ip route 192.168.2.0 255.255.255.0 192.168.4.2
ip route 192.168.5.0 255.255.255.252 192.168.4.14
ip route 192.168.6.0 255.255.255.0 192.168.4.14
ip flow-export version 9
access-list 10 permit 192.168.0.0 0.0.255.255
ip access-list extended LAN_Traffic
 permit tcp any host 192.168.1.34 eq smtp
 permit ip any any
ip access-list extended IT_Traffic
 deny ip any 192.168.1.56 0.0.0.7
 permit ip any any
ip access-list extended Sales_Traffic
 permit ip any 0.0.0.0 255.255.255.63
 deny ip any 192.168.0.0 0.0.255.255
 permit ip any any
ip access-list extended INTERNET
 permit tcp any any eq www
line con 0
line aux 0
line vty 0 4
 login
end
Router 2
version 15.4
hostname Router
no ip cef
no ipv6 cef
interface Loopback0
 ip address 192.168.7.2 255.255.255.0
interface Tunnel1
 ip address 100.100.100.1 255.255.255.252
 mtu 1476
 tunnel destination 1.1.1.1
 ip address 192.168.6.1 255.255.255.0
 duplex auto
 speed auto
 no ip address
 duplex auto
 speed auto
 shutdown
 ip address 192.168.5.2 255.255.255.0
 clock rate 2000000
 no ip address
 clock rate 2000000
 shutdown
 no ip address
 clock rate 2000000
 shutdown
 no ip address
 clock rate 2000000
 shutdown
interface Vlan1
 no ip address
 shutdown
router eigrp 1
 network 192.168.4.0
 network 192.168.5.0
 network 100.0.0.0
ip classless
ip route 0.0.0.0 0.0.0.0 Serial0/1/0
ip route 0.0.0.0 0.0.0.0 192.168.5.1
line con 0
line aux 0
line vty 0 4
 login
end
What is the common subnet that connects both routers (if there is one) ? Your tunnel destinations need to be an IP address configured on the respective other side of the tunnel. It should look like below:
R1
interface Tunnel1
mtu 1476
tunnel destination 192.168.4.14
R2
ip address 192.168.4.14 255.255.255.252
interface Tunnel1
mtu 1476
tunnel destination 192.168..4.13
