IPTV multicast routing in Cisco 6509
mohammad saeed
Level 5
Level 5
Hi Guys,
I have this scenario in my project for IPTV multicast routing : Streamer(udp)----6509 core----2960 access---STB
I configured the core and edge switch to route the multicast and multicast udp IPs is working only within the IPTV vlan but I want to be able to get the udp multicast with different vlans? How can I achieve thi through configuration?
here is my core 6509 configuration:
ip multicast-routing
ip igmp immediate-leave group-list 15
ip igmp snooping tcn query solicit
ip igmp snooping querier address 10.60.120.1(iptv vlan)
interface Vlan121
description "FOR IPTV VLAN"
ip address 10.60.120.1 255.255.252.0
ip pim sparse-dense-mode
in the 2960 access :
ip igmp snooping vlan 121 immediate-leave
any suggestion for my case, thanks for all
6 Replies 6
have you enabled 'ip pim sparse-dense-mode' on the other layer 3 VLAN (SVI) interfaces where you want the multicast traffic to go to ?
yes I made it under my other vlan need to get the stream but didn't work!
can you post the full configuration of the 6509 ? What do you have configured as RP ?
Core sw configuration attached. I configured RP : ip pim rp-address 10.60.120.1 (IPTV vlan Ip address)
Any Idea please!
I created a loop back inter face to be as RP but didn't work!
interface Loopback1
ip address 1.1.1.1 255.255.255.255
end
ip pim rp-address 1.1.1.1 override
