GRE Tunnel not functioning..
Mark Mattix
Level 6
Level 6
My topology is the following:
PC---R1---ISP(router)---R2---Switch---PC
I can sucessfully ping throughout the whole network but GRE tunneling does not seem to work. I was practicing IPsec VPNs before this which is why there are crypto configs that aren't applied. I removed them just to test out GRE. After configuring GRE and running a debug I get this message...
Feb 22 16:30:07.123: Tunnel0: GRE/IP to classify 202.170.100.33->202.170.100.30
(len=64 type=0x800 ttl=253 tos=0x0)
*Feb 22 16:30:07.123: Tunnel0: adjacency fixup, 202.170.100.30->202.170.100.33,
tos=0x0
tos=0x0
*Feb 22 16:30:07.123: Tunnel0: GRE/IP to classify 202.170.100.33->202.170.100.30
When I turn on Keepalive and run a debug is seems like GRE is working successfully because debug shows encapsulating and decapsulaing messages, but only on the keepalives and not when pinging or transferring data using an FTP.
Here are my configs for R1 and R2.
R1 Config...
version 12.4
crypto isakmp policy 101
encr aes
authentication pre-share
group 5
crypto isakmp key ciscovpnpass address 202.170.100.30
crypto ipsec transform-set PSO esp-aes esp-sha-hmac
crypto map R1-to-R2 101 ipsec-isakmp
set peer 202.170.100.30
set transform-set PSO
match address 101
interface Tunnel0
ip address 10.1.1.2 255.255.255.252
tunnel source GigabitEthernet0/1
tunnel destination 202.170.100.30
interface GigabitEthernet0/0
description Link to R1
duplex auto
speed auto
interface GigabitEthernet0/1
description Link to ISP
ip address 202.170.100.33 255.255.255.252
duplex auto
speed auto
interface Serial0/2/0
no ip address
shutdown
router ospf 10
log-adjacency-changes
network 192.168.1.0 0.0.0.255 area 0
network 202.170.100.32 0.0.0.3 area 0
ip classless
ip route 192.168.2.0 255.255.255.0 10.1.1.1
ip http server
no ip http secure-server
access-list 101 permit ip 192.168.1.0 0.0.0.255 192.168.2.0 0.0.0.255
R2 Config...
version 12.4
encr aes
group 5
crypto isakmp key ciscovpnpass address 202.170.100.33
crypto map R2-to-R1 101 ipsec-isakmp
! Incomplete
set peer 202.170.100.33
match address 101
interface Tunnel0
ip address 10.1.1.1 255.255.255.252
tunnel source FastEthernet0/0
tunnel destination 202.170.100.33
interface FastEthernet0/0
ip address 202.170.100.30 255.255.255.252
duplex auto
speed auto
interface FastEthernet0/1
ip address 192.168.2.1 255.255.255.0
duplex auto
speed auto
router ospf 10
network 192.168.2.0 0.0.0.255 area 0
network 202.170.100.28 0.0.0.3 area 0
!ip route 192.168.1.0 255.255.255.0 10.1.1.2
5 Replies 5
Edison Ortiz
please post the output from show interface tunnel0 and show ip route from both routers
your ISP may be blocking the GRE packet hence causing the tunnel NOT to come up.
Hi Edison, thanks for your help. I'm sorry, I should have stated that this is entirely a lab enviornment. ISP is just the name of the router. Here is the output of what you requested,
R1#show int tunnel0
Tunnel0 is up, line protocol is up
  Hardware is Tunnel
  Internet address is 10.1.1.2/30
  MTU 1514 bytes, BW 9 Kbit, DLY 500000 usec,
  Encapsulation TUNNEL, loopback not set
  Keepalive not set
  Tunnel source 202.170.100.33, destination 202.170.100.30
  Tunnel protocol/transport GRE/IP
    Key disabled, sequencing disabled
    Checksumming of packets disabled
  Tunnel TTL 255
  Fast tunneling enabled
  Tunnel transmit bandwidth 8000 (kbps)
  Tunnel receive bandwidth 8000 (kbps)
  Last input 01:08:04, output 01:23:47, output hang never
  Queueing strategy: fifo
  Output queue: 0/0 (size/max)
     1050 packets input, 74315 bytes, 0 no buffer
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     758 packets output, 59758 bytes, 0 underruns
Gateway of last resort is not set
     202.170.100.0/30 is subnetted, 2 subnets
O       202.170.100.28
           [110/2] via 202.170.100.34, 00:05:23, GigabitEthernet0/1
C       202.170.100.32 is directly connected, GigabitEthernet0/1
     10.0.0.0/30 is subnetted, 1 subnets
C       10.1.1.0 is directly connected, Tunnel0
C    192.168.1.0/24 is directly connected, GigabitEthernet0/0
S    192.168.2.0/24 [1/0] via 10.1.1.1
R2#show int tunnel0
  Hardware is Tunnel
  Internet address is 10.1.1.1/30
  MTU 1514 bytes, BW 9 Kbit/sec, DLY 500000 usec,
  Keepalive not set
  Tunnel source 202.170.100.30, destination 202.170.100.33
  Tunnel TTL 255
  Last input 00:00:23, output 00:00:23, output hang never
     739 packets input, 57918 bytes, 0 no buffer
     1092 packets output, 77289 bytes, 0 underruns
     0 unknown protocol drops
C       202.170.100.28 is directly connected, FastEthernet0/0
O       202.170.100.32 [110/2] via 202.170.100.29, 00:04:17, FastEthernet0/0
S    192.168.1.0/24 [1/0] via 10.1.1.2
C    192.168.2.0/24 is directly connected, FastEthernet0/1
using the command, debug tunnel on R2 and pinging from 192.168.2.1 on the router interface (by using the extended ping option to specify the interface) to 192.168.1.1 (R1 router interface) it shows,
Feb 22 20:10:59.446: Tunnel0: GRE/IP to classify 202.170.100.33->202.170.100.30
(len=124 type=0x800 ttl=253 tos=0x0)
*Feb 22 20:10:59.446: Tunnel0: GRE/IP encapsulated 202.170.100.30->202.170.100.3
3 (linktype=7, len=124)
This leads me to believe that it encapsulated the packet in GRE successfully, would I be correct about that?
Now when I ping from PC to PC I see this from debug tunnel,
*Feb 22 20:11:53.238: Tunnel0: GRE/IP to classify 202.170.100.33->202.170.100.30
(len=84 type=0x800 ttl=253 tos=0x0)
R2#
*Feb 22 20:11:54.226: Tunnel0: adjacency fixup, 202.170.100.30->202.170.100.33,
tos=0x0
I don't know what to think of this output but I assume it did not successfully encapsulate in GRE.
Well a CCNP I know has informed me that the GRE tunnel is working. I'm not sure why I'm getting the
adjacency fixup mesage but I believe it could have someone to do with OSPF. I did disable OSPF and applied static routes and got the same error so I'm not 100% certain. I would like to view the packets to ensure they're being encalsulated but the "monitor capture" command is not available in my IOS.
You won't be able to see transit traffic (traffic not originated by the router) via a debug unless you enable process-switching on the interfaces (not recommended).
Your GRE tunnel is working per the output you've provided.
Edison
