GRE Tunnel or mGRE tunnel ?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
09-01-2013 09:40 PM - edited 03-04-2019 08:55 PM
Dear Experts,
Please find the Topology.
Based on it which will be the best suitable : 1. Point to Point GRE tunnel 2. Point to Multi-Point GRE Tunnel at DR1 and DR2.
How the Ruting should be if I want to use BGP over GRE Tunnel Interface?
GRE Tunnel will be used for only DC-DR replication . Rest traffic will move via MPLS link.
- Labels:
Routing Protocols
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-02-2013 12:02 AM
Are there only these small amount of sites or do you plan to add many more in the future? With a small amount of tunnels I always prefer point-to-point-tunnels between all sites as they give you more control. With mGRE you need an additional layer of configuration like NHRP to map the next-hop. If there is no scalability-problem I try to avoid these additional steps to keep it simple where possible. But if the amounts of sites increase there is a real configuration-benefit in using mGRE-tunnels.
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-02-2013 02:36 AM
So in my case also P2P GRE tunnel is good.
Can we use BGP with GRE Tunnel for selected traffic only?
How?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-02-2013 02:42 AM
You can use the GRE-tunnel nearly like a normal interface. BGP which is using unicast-communication is no problem, but you can also send multicast-traffic through the tunnel for your IGP. Filtering of traffic is done as usual with in- and outgoing ACLs.
