Router 819G - Auto-switch & failover between two Cellular Nets
Hi all,
I have a Cisco 819G WAN Router with the following specifications:
Router3G#show inventory
NAME: "C819G+7-K9 chassis", DESCR: "C819G+7-K9 chassis"
PID: C819G+7-K9        , VID: V01 , SN: xxxxxxxxxxx
NAME: "C819 Mother board on Slot 0", DESCR: "C819 Mother board"
NAME: "Modem 0 on Cellular0", DESCR: "Sierra Wireless Mini Card MC8705 HSPA+R7 modem"
PID: 8705              , VID: 1.0, SN: xxxxxxxxxxx
and employee Cisco IOS Software, C800 Software (C800-UNIVERSALK9-M), Version 15.1(4)M3, RELEASE SOFTWARE (fc1)
The router have dual SIM enabled from diferents ISPs, and I use secesfully the following chat-script for both:
chat-script gsm "" "AT!SCACT=1,1" TIMEOUT 60 "OK"
After the device power on, the Dial-In is successful for SIM 0 (Profile 1) obtaining an IP address by DHCP, and the Profile 2 (Inactive) is associated to SIM 1.
Router3G#show cell 0 profile
Profile 1 = ACTIVE*
PDP Type = IPv4
PDP address = A.B.C.D
Access Point Name (APN) = imovil.entelpcs.cl
Authentication = CHAP
Username: xxxxxxx, Password: xxxxxxx
        Primary DNS address = 200.63.56.3
        Secondary DNS address = 200.63.56.5
Profile 2 = INACTIVE
PDP Type = IPv4
Access Point Name (APN) = web.tmovil.cl
Username: web, Password: web
* - Default profile
Configured default profile for active SIM 0 is profile 1.
Router3G#
   My current problem is that I tryied to simulate a conenction fault, e.g. termination by mobile provider, but the router dont switch-over into the second profile in order to start a new Dial-In with the second ISP.
  I attached at following the current configuration:
Router3G#show running-config
Building configuration...
Current configuration : 2831 bytes
! Last configuration change at 00:31:05 UTC Wed Apr 18 2012
! NVRAM config last updated at 00:02:54 UTC Wed Apr 18 2012
version 15.1
service internal
hostname Router3G
boot-start-marker
boot-end-marker
enable secret 5 $1$Qr5C$q3BTcNUQzx9.oL7BRpK0k/
no aaa new-model
ip source-route
ip cef
ip dhcp excluded-address 192.168.31.209
ip dhcp pool SomeDHCPpool
import all
network 192.168.31.208 255.255.255.240
default-router 192.168.31.209
dns-server 4.2.2.2
ip domain name XYZ.com
no ipv6 cef
chat-script gsm "" "AT!SCACT=1" TIMEOUT 60 "OK"
license udi pid C819G+7-K9 sn FTXxxxxxxx
no spanning-tree vlan 1
username engineer password 0 cisco
controller Cellular 0
gsm sim profile 2 slot 1
gsm sim max-retry 65535
gsm failovertimer 1
ip ssh version 2
interface Cellular0
ip address negotiated
ip flow ingress
ip flow egress
ip nat outside
ip virtual-reassembly in
encapsulation slip
dialer in-band
dialer idle-timeout 2147483
dialer string gsm
dialer-group 1
async mode interactive
interface FastEthernet0
description "Internal LAN"
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface GigabitEthernet0
no ip address
shutdown
duplex auto
speed auto
interface Serial0
no ip address
shutdown
clock rate 2000000
interface Vlan1
ip address 192.168.31.209 255.255.255.240
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat inside
ip tcp adjust-mss 1452
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source route-map nonat interface Cellular0 overload
ip route 0.0.0.0 0.0.0.0 Cellular0
access-list 1 permit any
access-list 131 remark ***** NAT ACL *****
access-list 131 deny   ip 192.168.31.208 0.0.0.15 10.0.1.0 0.0.0.255
access-list 131 permit ip 192.168.31.208 0.0.0.15 any
dialer-list 1 protocol ip list 1
route-map nonat permit 10
match ip address 131
control-plane
line con 0
exec-timeout 0 0
password cisco
login
line aux 0
line 3
script dialer gsm
login
modem InOut
no exec
transport input all
rxspeed 21600000
txspeed 5760000
line vty 0 4
login local
transport input all
end
  I realy appreciate any comment in order to enable Dual-SIM switch over
5 Replies 5
mavespig
Level 3
Level 3
Hi Claudio,
can you post the full 'show cell 0 all', and also collect these debugs while the failover should occur:
- deb chat
- deb dialer
- deb ppp nego
I can see that the profile should be already associated with the SIM: gsm sim profile 2 slot 1
The failover should start after a minute, be sure to run the debugs long enough.
How do you simulate the failure on the main SIM?
On a side note, there are a couple of config lines that should be corrected:
interface Cellular0
     encapsulation slip    <<<< It should be PPP.
      dialer idle-timeout 2147483  <<< why a value so high? If you want the timeout to be disabled, just use 0
line 3
      rxspeed 21600000
      txspeed 5760000     <<< these two commands are unnecessary, you can't see the 3G speed manually
Hope this helps
Marco
Marco
   Please find attached the requested show commands:
Router3G#show cellular 0 all
Hardware Information
Modem Firmware Version = T1_0_3_2AP R361 CNSZ
Modem Firmware built = 04/15/11
Hardware Version = 1.0
International Mobile Subscriber Identity (IMSI) = 730011165268140
International Mobile Equipment Identity (IMEI) = 357115040062080
Integrated Circuit Card ID (ICCID) = 89560100000318181407
Mobile Subscriber International Subscriber
IDentity Number (MSISDN) =
Factory Serial Number (FSN) = CC3239101641007
Modem Status = Online
Current Modem Temperature = 33 deg C, State = Normal
PRI SKU ID = 9900198, SKU Rev. = 1.2
Profile Information
Profile 1 = ACTIVE*
PDP Type = IPv4
PDP address = 186.10.C.D
Username: entelpcs, Password: entelpcs
        Primary DNS address = 200.63.56.4
        Secondary DNS address = 200.63.56.6
PDP Type = IPv4
* - Default profile
Data Connection Information
Data Transmitted = 3049738 bytes, Received = 9733990 bytes
Profile 1, Packet Session Status = ACTIVE
        IP address = 186.10.7.145
        Negotiated QOS Parameters:
        Precedence = Normal Priority, Delay = Class 2
        Reliability = Unack GTP, LLC, Ack RLC, Protected data
        Peak = 256 kB/sec, Mean = 50000 kB/hr
        Traffic Class = Interactive
        Uplink Max = 2048kbps, Guaranteed = 16kbps
        Downlink Max = 2048kbps, Guaranteed = 64kbps
        Max SDU size = 1500 bytes
        SDU error ratio = 1E-4, BER = 1E-5
Profile 2, Packet Session Status = INACTIVE
        Inactivity Reason = Normal inactivate state
Profile 3, Packet Session Status = INACTIVE
Profile 4, Packet Session Status = INACTIVE
Profile 5, Packet Session Status = INACTIVE
Profile 6, Packet Session Status = INACTIVE
Profile 7, Packet Session Status = INACTIVE
Profile 8, Packet Session Status = INACTIVE
Profile 9, Packet Session Status = INACTIVE
Profile 10, Packet Session Status = INACTIVE
Profile 11, Packet Session Status = INACTIVE
Profile 12, Packet Session Status = INACTIVE
Profile 13, Packet Session Status = INACTIVE
Profile 14, Packet Session Status = INACTIVE
Profile 15, Packet Session Status = INACTIVE
Profile 16, Packet Session Status = INACTIVE
Network Information
Current Service Status = Normal, Service Error = None
Current Service = Combined
Packet Service = HSPA+ (Attached)
Packet Session Status = Active
Current Roaming Status = Home
Network Selection Mode = Automatic
Country = CHL, Network = ENTEL PC
Mobile Country Code (MCC) = 730
Mobile Network Code (MNC) = 1
Location Area Code (LAC) = 13502
Routing Area Code (RAC) = 100
Cell ID = 21032
Primary Scrambling Code = 22
PLMN Selection = Automatic
Registered PLMN =  , Abbreviated =
Service Provider = entel
Radio Information
Radio power mode = ON
Current Band = WCDMA 1900, Channel Number = 687
Current RSSI = -65 dBm
Band Selected = Auto
Number of nearby cells = 2
Cell 1
        Primary Scrambling Code = 0x16
        RSCP = -68 dBm, ECIO = -12 dBm
Cell 2
        Primary Scrambling Code = 0xE
        RSCP = -72 dBm, ECIO = -13 dBm
Modem Security Information
Active SIM = 0
SIM switchover attempts = 0
Card Holder Verification (CHV1) = Disabled
SIM Status = OK
SIM User Operation Required = None
Number of CHV1 Retries remaining = 3
GPS Information
GPS Info
GPS State: GPS disabled
SMS Information
Incoming Message Information
SMS stored in modem = 0
SMS archived since booting up = 0
Total SMS deleted since booting up = 0
Storage records allocated = 0
Storage records used = 0
Number of callbacks triggered by SMS = 0
Number of successful archive since booting up = 0
Number of failed archive since booting up = 0
Outgoing Message Information
Total SMS sent successfully = 0
Total SMS send failure = 0
Number of outgoing SMS pending = 0
Last Outgoing SMS Status = SUCCESS
Copy-to-SIM Status =     0x0
Send-to-Network Status = 0x0
Report-Outgoing-Message-Number:
  Reference Number =     0
  Result Code =          0x0
  Diag Code =            0x0 0x0 0x0 0x0 0x0
SMS Archive URL =
Router3G#
  To generate the failover condition over the main SIM (SIM card in slot 0 and engaged to Profile 1) I run the following commands:
Router3G(config)#service internal
Router3G#test cellular 0 modem-power-cycle
Router3G#debug chat
Chat scripts activity debugging is on
Router3G#debug dialer
Dial on demand events debugging is on
Router3G#debug ppp negotiation
PPP protocol negotiation debugging is on
Router3G#
Apr 18 14:41:23.779: %CISCO800-2-MODEM_DOWN: Cellular0 modem is now DOWN.
Apr 18 14:41:28.859: %LINK-5-CHANGED: Interface Cellular0, changed state to reset
Apr 18 14:41:29.859: %LINEPROTO-5-UPDOWN: Line protocol on Interface Cellular0, changed state to down
Apr 18 14:41:32.079: %CISCO800-2-MODEM_UP: Cellular0 modem is now UP.
Modem Power cycled successfully
Router3G#
Apr 18 14:41:33.859: %LINK-3-UPDOWN: Interface Cellular0, changed state to down
Apr 18 14:41:43.859: Ce0 DDR: re-enable timeout
Apr 18 14:41:44.939: Ce0 DDR: place call
Apr 18 14:41:44.939: Ce0 DDR: Dialing cause ip (s=192.168.31.210, d=204.56.87.173)
Apr 18 14:41:44.939: Ce0 DDR: Attempting to dial gsm
Apr 18 14:41:44.939: CHAT3: Attempting async line dialer script
Apr 18 14:41:44.939: CHAT3: Dialing using Modem script: gsm & System script: none
Apr 18 14:41:44.943: CHAT3: process started
Apr 18 14:41:44.943: CHAT3: Asserting DTR
Apr 18 14:41:44.943: CHAT3: Chat script gsm started
Apr 18 14:41:44.943: CHAT3: Sending string: AT!SCACT=1
Apr 18 14:41:44.943: CHAT3: Expecting string: OK
Apr 18 14:41:47.999: CHAT3: Completed match for expect: OK
Apr 18 14:41:48.011: CHAT3: Chat script gsm finished, status = Success
Apr 18 14:41:50.011: %LINK-3-UPDOWN: Interface Cellular0, changed state to up
Apr 18 14:41:50.011: Ce0 DDR: Dialer statechange to up
Apr 18 14:41:50.011: Ce0 DDR: Dialer call has been placed
Apr 18 14:41:50.011: Ce0 DDR: dialer protocol up
Apr 18 14:41:51.011: %LINEPROTO-5-UPDOWN: Line protocol on Interface Cellular0, changed state to up
Router3G#
Hi Claudio,
'test cellular 0 modem-power-cycle' will actually reset the whole card, so when the card will come back online it will still use the first SIM.
To simulate a switchover you either need to remove physically the SIM, or use the command 'cellular 0 gsm sim activate slot x'
Let me know if this works.
Marco
AndersBramsen
Can I ask a question?
I have tryed to acomplish PBR, so i could choose trafic to go via other ISP...
What is the No NAT PBR for? Is that because you also have a Asa Firewall on ?
So that could maybe be why i not can make myt PBR working outside in?
BR Anders Bramsen
Amit Singh
Hi Caludio,
I do not see the second profile attached to the controller cellular 0.
gsm failovertimer 1
Please configure both the profiles under the cellular 0.
Also, why you have MAX-retry that high?
