GRE Tunnel over 4G Internet connection
mdasifsm1
we have some home offices which i am trying to connect over GRE tunnel through cisco router 881.
i connected some home offices using DSL lines of various service providers and its working fine , but when ever i am trying to configure the tunnel over 4G internet connection which uses sim cards to connect to internet, the tunnel not getting built. I Changed the 4G router settings to 3G but still no success.
here is the config
Server:
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
lifetime 3600
crypto isakmp key XXXXX address 0.0.0.0 0.0.0.0
interface Tunnel0
ip address 172.18.18.1 255.255.255.0
no ip redirects
ip mtu 1400
ip nhrp authentication XXXXX
ip nhrp map multicast dynamic
ip nhrp network-id 254
ip nhrp registration no-unique
ip tcp adjust-mss 1360
delay 1000
tunnel source GigabitEthernet0/0.1276
tunnel mode gre multipoint
tunnel key 199
Client :-
____________
encr 3des
group 2
lifetime 3600
crypto isakmp key XXXXX address 34.88.203.122
interface Tunnel0
bandwidth 1024
ip address 172.18.18.10 255.255.255.0
no ip redirects
ip mtu 1400
ip nhrp map multicast 34.88.203.122
ip nhrp map 172.18.18.1 34.88.203.122
ip nhrp nhs 172.18.18.1
delay 1000
tunnel source FastEthernet4
tunnel destination 34.88.203.122
tunnel key 199
can any one help me....
Hello, Asif.
Could you please provide us a configuration that doesn't work for you (physical and logical interfaces, static routes and crypto cnfiguration).
So far I see you are using Fa4 as a source for tunnel, not you 3G/4G interface.
And I can't see any encryption on your tunnel; this could be an issue if your 3G/4G obtain private (RFC1918) ip-address from provider.
PS: please remember, that it's recommended to use Dialer interface and not to assign ip-address to your Cellular interface.
5 Replies 5
Hello, Asif.
Hi Mikail,
Thankyou for the reply
There is nothing much, the same config is working on DSL lines but not on 3G or 4G connections.
no cellular module on cisco 881 required as the DSL,3g and 4G modem provides Ethernet connection to spoke.
at present i don't need any encryption, the modems getting public ip add, and provides private ip to spoke via in-built dhcp servers.
Here is the topology ..
Hello, Asif.
The issue could be due to modem is doing any kind of firewall, or it's not forwarding GRE to the internal interface (NAT issue).
Thanks mikhail,
The issue was with encrytion, eventhough the modems obtaining public ip address, the tunnel failed to get created.
i configured IPSec and its working fine, audio also not getting effected.
Hi mdasifsm1
I also have same requirement as yours' . It would be much appreciated if you can share the configuration which works for you?
Thank you,
Laxman
