GRE Tunnel Routing Problem
Andy Guley
I created a GRE tunnel.  The tunnel is up and functioning fine.  I am having a routing issue on one side of the network.
Router 1
interface Tunnel5
ip address 10.255.111.2 255.255.255.252
ip mtu 1400
tunnel source 10.110.141.254
tunnel destination 10.87.5.2
S     192.168.21.0/24 [1/0] via 10.255.111.1
Router 2
interface Tunnel5
ip address 10.255.111.1 255.255.255.252
ip mtu 1400
tunnel source 10.87.5.2
tunnel destination 10.110.141.254
S    192.168.20.0/24 [1/0] via 10.255.111.2
From router 1 data travels correctly accross the tunnel:
Tracing the route to 192.168.21.254
VRF info: (vrf in name/id, vrf out name/id)
  1 10.255.111.1 12 msec 8 msec 8 msec
  2 10.87.5.9 8 msec *  8 msc
From router 2 it keeps bouncing between the tunnel and serial interface on the router:
traceroute 192.168.20.200
1 10.255.111.2 8 msec 8 msec 8 msec
2 10.110.11.46 16 msec 16 msec 16 msec
3 10.110.11.1 8 msec 8 msec 8 msec
4 10.255.111.2 12 msec 16 msec 12 msec
5 10.110.11.46 24 msec 24 msec 24 msec
6 10.110.11.1 12 msec 16 msec 12 msec 1 10.255.111.2 8 msec 8 msec 8 msec
10.110.11.46 is the serial interface on the router where the 10.255.111.2 tunnel is created.  10.110.11.1 is an interface for MPLS.
23 Replies 23
Andy,
Ok, let me make sure I get this correct.
Is that 'show run int vlan 333' from the Switch or from R1?
If (interface vlan 333) is from R1, can you post the results from 'show int vlan333' ?
vlan333 is the switch hanging off of the router.
Andy,
Ok, Cool. So on R1, there is a physical port that is connected to this switch. On R1, can you post the results from 'show run int X' where X is the port on Router 1 that is going to this SW.
R1
Show run int gi0/1
no ip address
ip flow ingress
ip flow egress
duplex full
speed 100
Here is the config on the switch that it hooks into as well:
interface GigabitEthernet0/1
description CISCO2911 Gig 0/1
switchport access vlan 141
switchport mode trunk
speed 100
duplex full
srr-queue bandwidth share 10 10 60 20
srr-queue bandwidth shape  10  0  0  0
queue-set 2
mls qos trust cos
auto qos voip trust
rmon collection stats 1 owner PMmonitor
rmon collection history 1 owner PMmonitor buckets 50 interval 1800
Andy,
So when it gets to R1, it's going to do a route lookup, and obviously take the default route, since there is no default route.
On Gi0/1, on R1, configure the IP address of 192.168.20.x, X will be some number that you want to use. Once this happens, it will become a directly connected route.
On R1, after you do this, you will see 192.168.20.0 255.255.255.0, and it will ARP out for any host on 192.168.20.x/24.
Is this switch for testing purposes?
Its not for testing purposes but I can play with it a little.  The swtich is a 3560 and routing is not currently enabled on it.  Can I enable routing on the switch and then put a static route on the router?
Ip route 192.168.20.0 255.255.255.0  via 192.168.20.200?
Andy,
We'll, this 3560 switch has an SVI on it, so you should be able to put an IP address on R1 and make it a L3 link basically.
you can try that static route command.
Disregard last post.  I created the interface and it is now routing correctly.  I really appreciate all of your help on this issue.
Thank you very much.
Andy,
No problem glad I could help!
