GRE Tunnel won't come up?
Chrisb6122
I'm having a bit of a strange issue getting a single GRE tunnel to come up between my head office and a remote site. I'll be the first to admit, I'm quite new to new to setting up vpn's and the like so forgive me if I'm missing anything painfully obivious. The head office has around 14 different connections coming off all setup the same way with an IPSec VPN with a GRE tunnel to encrypt the data.
Headoffice#sh run int t52
interface Tunnel52
description Primary
bandwidth 1024
ip address 172.29.0.209 255.255.255.252
ip access-group pla_in in
no ip unreachables
ip rip advertise 15
tunnel source Loopback0
tunnel destination 172.28.0.33
tunnel path-mtu-discovery
Headoffice#sh ip int t52
Tunnel52 is up, line protocol is down
  Internet address is 172.29.0.209/30
  Broadcast address is 255.255.255.255
  Address determined by non-volatile memory
  MTU is 1476 bytes
  Helper address is not set
  Directed broadcast forwarding is disabled
  Multicast reserved groups joined: 224.0.0.9
  Outgoing access list is not set
  Inbound  access list is pla_in
  Proxy ARP is enabled
  Local Proxy ARP is disabled
  Security level is default
  Split horizon is enabled
  ICMP redirects are always sent
  ICMP unreachables are never sent
  ICMP mask replies are never sent
  IP fast switching is enabled
  IP fast switching on the same interface is disabled
  IP Flow switching is disabled
  IP CEF switching is enabled
  IP Feature Fast switching turbo vector
  IP Feature CEF switching turbo vector
  IP multicast fast switching is enabled
  IP multicast distributed fast switching is disabled
  IP route-cache flags are Fast, CEF
  Router Discovery is disabled
  IP output packet accounting is disabled
  IP access violation accounting is disabled
  TCP/IP header compression is disabled
  RTP/IP header compression is disabled
  Policy routing is disabled
  Network address translation is disabled
  WCCP Redirect outbound is disabled
  WCCP Redirect inbound is disabled
  WCCP Redirect exclude is disabled
  BGP Policy Mapping is disabled
interface Loopback0
ip address 172.28.255.1 255.255.255.255
remoteoffice#sh run int t52
Building configuration...
Current configuration : 206 bytes
interface Tunnel52
description Plastica primary P2P GRE tunnel over IPsec VPN
ip address 172.29.0.210 255.255.255.252
ip rip advertise 15
tunnel source Loopback1
tunnel destination 172.28.255.1
end
remoteoffice#sh ip int t52
Tunnel52 is up, line protocol is up
  Internet address is 172.29.0.210/30
  Address determined by setup command
  MTU is 1476 bytes
  Inbound  access list is not set
  ICMP unreachables are always sent
  IP CEF Feature Fast switching turbo vector
interface Loopback1
ip address 172.28.0.33 255.255.255.255
I can post more information if needed but I'm a tad stuck on this one, the routing I believe is correct as are the ACL's.
I would be most greatful for any help!
15 Replies 15
Calin C.
Level 5
Level 5
Do a simple test first,
From the HQ to Remote office, can you ping the tunnel destination using tunnel source?
e.g. ping 172.28.0.33 source 172.28.255.1
You can try also viceversa, but if you don't have some fancy firewall in place one direction should be enough to test.
If it's not working, then here is your first step to troubleshoot.
Let us know and we can continue to give you some advices.
HTH,
Calin
Thank you,
this is from HQ
#ping 172.28.0.33 source 172.28.255.1
Sending 5, 100-byte ICMP Echos to 172.28.0.33, timeout is 2 seconds:
Packet sent with a source address of 172.28.255.1
Success rate is 100 percent (5/5), round-trip min/avg/max = 56/58/60 ms
this is from the remote office
#ping 172.28.255.1 source 172.28.0.33
Sending 5, 100-byte ICMP Echos to 172.28.255.1, timeout is 2 seconds:
Packet sent with a source address of 172.28.0.33
Success rate is 100 percent (5/5), round-trip min/avg/max = 60/60/64 ms
Looks like they can ping but the tunnel still shows as down at the HQ?
Chris
On HQ, what do you have here in ACL pla_in ?
Take it out for some seconds. Is the interface coming up?
Calin
The pla_in ACL has the following in it,
ip access-list extended pla_in
remark 1 Permit traffic between associated networks
remark 1 na
remark 2 Permit return traffic berween connected networks
permit icmp 172.29.0.0 0.0.255.255 172.29.0.0 0.0.255.255 echo-reply
permit tcp 172.29.0.0 0.0.255.255 172.29.0.0 0.0.255.255 established
remark 3 Permit GRE between tunnel endpoints
permit gre 172.28.0.0 0.0.255.255 172.28.0.0 0.0.255.255
remark 4 Permit RIP from tunnel networks to RIP routers
permit udp 172.29.0.0 0.0.255.255 host 224.0.0.9 eq rip
remark 5 Deny traffic to non hosted private networks
deny   ip any 10.1.2.0 0.0.1.255
deny   ip any 172.16.0.0 0.15.255.255
remark 6 Permit traffic from associated and connected networks to hosted networks
permit ip 172.19.18.32 0.0.0.7 10.0.0.0 0.255.255.255
permit ip 172.29.0.0 0.0.255.255 10.0.0.0 0.255.255.255
remark 7 Permit traffic from associated  networks to Internet
remark 7 na
remark 8 Deny (or log) everything else
deny   ip any any
I've removed the ACL but its still not coming back up.
Chris
on your tun interface on router the description says GREoIPsec. So, are you running GREoIPsec?
Does your encryption domain have the appropriate subnets in there. Is the interresting traffic configured properly
can you so a sh cryp ipsec sa
Might be good idea to attach the ful config here
Kishore
Think so, the IPSec VPN terminates on a firewall prior to letting the interesting traffic through to the router where the GRE tunnel terminates.
remote office#sh crypto isakmp sa
IPv4 Crypto ISAKMP SA
dst             src             state          conn-id slot status
195.200.145.227 81.5.131.153    QM_IDLE           1001    0 ACTIVE
#sh crypto ipsec sa
interface: Dialer1
    Crypto map tag: vpnmap, local addr 81.5.131.153
   protected vrf: (none)
   local  ident (addr/mask/prot/port): (172.28.0.33/255.255.255.255/0/0)
   remote ident (addr/mask/prot/port): (172.28.255.0/255.255.255.0/0/0)
   current_peer 195.200.145.227 port 500
     PERMIT, flags={origin_is_acl,}
    #pkts encaps: 265, #pkts encrypt: 265, #pkts digest: 265
    #pkts decaps: 210, #pkts decrypt: 210, #pkts verify: 210
    #pkts compressed: 0, #pkts decompressed: 0
    #pkts not compressed: 0, #pkts compr. failed: 0
    #pkts not decompressed: 0, #pkts decompress failed: 0
    #send errors 5, #recv errors 0
     local crypto endpt.: 81.5.131.153, remote crypto endpt.: 195.200.145.227
     path mtu 1500, ip mtu 1500
     current outbound spi: 0xC5DB17A9(3319469993)
     inbound esp sas:
      spi: 0xABF5BC53(2885008467)
        transform: esp-256-aes esp-sha-hmac ,
        in use settings ={Tunnel, }
        conn id: 3, flow_id: C87X_MBRD:3, crypto map: vpnmap
        sa timing: remaining key lifetime (k/sec): (4493568/823)
        IV size: 16 bytes
        replay detection support: Y
        Status: ACTIVE
     inbound ah sas:
     inbound pcp sas:
     outbound esp sas:
        conn id: 4, flow_id: C87X_MBRD:4, crypto map: vpnmap
        sa timing: remaining key lifetime (k/sec): (4493553/822)
        IV size: 16 bytes
        Status: ACTIVE
     outbound ah sas:
     outbound pcp sas:
interface: Virtual-Access2
     inbound esp sas:
        sa timing: remaining key lifetime (k/sec): (4493568/821)
        IV size: 16 bytes
        Status: ACTIVE
     inbound ah sas:
     inbound pcp sas:
     outbound esp sas:
        sa timing: remaining key lifetime (k/sec): (4493553/820)
        IV size: 16 bytes
        Status: ACTIVE
     outbound ah sas:
     outbound pcp sas:
Please see the attached file for the remote office.
Chris
You need to allow GRE on the firewall. Please check if port 47 is allowed on the firewall
Cheers
Kishore
I mean protocol 47 not port ;)
Thank you,
I believe it's allowed through because as i say atleast 14 other sites are working fine using the same setup,
This is all the information relating to the remote office on the firewall
access-list outside_cryptomap_9000_remote office extended permit ip 172.28.255.0 255.255.255.0 host 172.28.0.33
crypto map outside_map 9000 match address outside_cryptomap_9000_remote office
crypto map outside_map 9000 set pfs group5
crypto map outside_map 9000 set peer 81.5.131.153
crypto map outside_map 9000 set transform-set AES256
I'm still at a loss of what could be wrong here.
just checking  your remote site confguration.
interface Loopback1
description terminates GRE tunnels over IPsec
ip address 172.28.0.33 255.255.255.252               <<<< shouldnt this be a /32??
because in your interesting traffic on the frewall your remote subnet in encryption domain is host 172.28.0.33 which is a /32 address
Also the ACL on the remote site is
ip access-list extended protected
permit ip host 172.28.0.33 172.28.255.0 0.0.0.255       <<< your saying host but your loopback is configured as /30
change the loopback address to a /32 and see if that helps
Kishore
Thanks Kishore,
I've changed both of those addresses to be /32
so they now read
I still can;t even ping the inside interface (172.19.18.37) from the HQ router.
Thanks again
Chris
Is the Tunnel up on both ends. ?  Can you ping the Tunnel interfaces from each site?
can you see the RIP routes being advertised at both ends?
Also is the vlan 1 interface up on the remote router?? because on some low end routers if nothing is plugged into the ethernet ports then the Vlan1 remains down (line protocol)
can you execute the below commands on HQ and Remote router paste the results here
HQ
sh ip rip database 172.19.18.37
sh ip route 172.19.18.37
Remote
sh ip int brief
Just out of curiosity is this a Cisco 837 or a 877?
Cheers
Thanks again for your reply.
The tunnel is only up up on the remote end, at HQ its only showing as up down. The remote end router isa cisco 877.
I can ping successfully 172.28.255.1 from 172.28.0.33 and vice a versa.
The vlan is up (I did have to go check though)
HQ
HQ#sh ip rip database 172.19.18.37 255.255.255.252
%Route not in database
HQ#sh ip route 172.19.18.37
Routing entry for 172.16.0.0/12, supernet
  Known via "static", distance 1, metric 0
  Redistributing via ospf 1024, rip
  Advertised by ospf 1024 subnets
                rip
  Routing Descriptor Blocks:
  * 10.3.2.254
      Route metric is 0, traffic share count is 1
Remote
Remote#sh ip int brief
Interface                  IP-Address      OK? Method Status                Prot
ocol
FastEthernet0              unassigned      YES unset  up                    up
FastEthernet1              unassigned      YES unset  up                    down
FastEthernet2              unassigned      YES unset  up                    down
FastEthernet3              unassigned      YES unset  up                    down
ATM0                       unassigned      YES NVRAM  up                    up
Vlan1                      172.19.18.37    YES NVRAM  up                    up
Tunnel52                   172.29.0.210    YES NVRAM  up                    up
Loopback1                  172.28.0.33     YES NVRAM  up                    up
Loopback0                  unassigned      YES NVRAM  up                    up
Dialer1                    81.5.131.153    YES NVRAM  up                    up
Virtual-Access1            unassigned      YES unset  up                    up
Virtual-Access2            unassigned      YES unset  up                    up
Remote#sh ip rip database 172.19.18.37 255.255.255.252
Remote#sh ip route 172.19.18.37
Routing entry for 172.19.18.0/24
  Known via "connected", distance 0, metric 0 (connected, via interface)
  Redistributing via rip
  Advertised by rip
  * directly connected, via Vlan1
Thanks again for your help!
Chris
Chrisb6122
Thanks for all your help.
The problem has now been resolved.
The issue was an incorrect subnet mask placed on the VLAN interface at the remote end, once it was changed to a /28 rip learned the proper network and started to transmit data.
Thanks for your help.
