GRE Tunnel won't come up?
Chrisb6122
I'm having a bit of a strange issue getting a single GRE tunnel to come up between my head office and a remote site. I'll be the first to admit, I'm quite new to new to setting up vpn's and the like so forgive me if I'm missing anything painfully obivious. The head office has around 14 different connections coming off all setup the same way with an IPSec VPN with a GRE tunnel to encrypt the data.
Headoffice#sh run int t52
interface Tunnel52
description Primary
bandwidth 1024
ip address 172.29.0.209 255.255.255.252
ip access-group pla_in in
no ip unreachables
ip rip advertise 15
tunnel source Loopback0
tunnel destination 172.28.0.33
tunnel path-mtu-discovery
Headoffice#sh ip int t52
Tunnel52 is up, line protocol is down
  Internet address is 172.29.0.209/30
  Broadcast address is 255.255.255.255
  Address determined by non-volatile memory
  MTU is 1476 bytes
  Helper address is not set
  Directed broadcast forwarding is disabled
  Multicast reserved groups joined: 224.0.0.9
  Outgoing access list is not set
  Inbound  access list is pla_in
  Proxy ARP is enabled
  Local Proxy ARP is disabled
  Security level is default
  Split horizon is enabled
  ICMP redirects are always sent
  ICMP unreachables are never sent
  ICMP mask replies are never sent
  IP fast switching is enabled
  IP fast switching on the same interface is disabled
  IP Flow switching is disabled
  IP CEF switching is enabled
  IP Feature Fast switching turbo vector
  IP Feature CEF switching turbo vector
  IP multicast fast switching is enabled
  IP multicast distributed fast switching is disabled
  IP route-cache flags are Fast, CEF
  Router Discovery is disabled
  IP output packet accounting is disabled
  IP access violation accounting is disabled
  TCP/IP header compression is disabled
  RTP/IP header compression is disabled
  Policy routing is disabled
  Network address translation is disabled
  WCCP Redirect outbound is disabled
  WCCP Redirect inbound is disabled
  WCCP Redirect exclude is disabled
  BGP Policy Mapping is disabled
interface Loopback0
ip address 172.28.255.1 255.255.255.255
remoteoffice#sh run int t52
Building configuration...
Current configuration : 206 bytes
interface Tunnel52
description Plastica primary P2P GRE tunnel over IPsec VPN
ip address 172.29.0.210 255.255.255.252
ip rip advertise 15
tunnel source Loopback1
tunnel destination 172.28.255.1
end
remoteoffice#sh ip int t52
Tunnel52 is up, line protocol is up
  Internet address is 172.29.0.210/30
  Address determined by setup command
  MTU is 1476 bytes
  Inbound  access list is not set
  ICMP unreachables are always sent
  IP CEF Feature Fast switching turbo vector
interface Loopback1
ip address 172.28.0.33 255.255.255.255
I can post more information if needed but I'm a tad stuck on this one, the routing I believe is correct as are the ACL's.
I would be most greatful for any help!
15 Replies 15
Chris
Thanks for posting to the forum to tell us that the problem was solved and what the problem was. I had been watching this thread and am glad to know how it turned out.
Rick
Rick
