Grouping multiple BRI links for Video call
Please let me know the procedure or configuration details for grouping multiple BRI links to get 384 kbps bandwidth which can be used for Video call.
Please help me out!!!
6 Replies 6
Giuseppe Larosa
Hello Krishna,
you need to use PPP multilink with DDR
see the following document:
http://www.cisco.com/en/US/tech/tk713/tk507/technologies_tech_note09186a0080112d3b.shtml
you need to use at least 3 BRI to reach 384 kbps
Hope to help
Giuseppe
Note that due to IP overhead, the provided throughput will be less than 384 kbps to the application, you will then need a fourth BRI or reduce used bandwidth.
Hi Giuseppe,
Thanks for your reply.
Can it possible to communicate(making Video call) these Grouped BRI's (using multilink ppp)with E1 PRI at other end?
Hello Krishna,
yes this is possible from the ISDN point of view this means using multiple B channels on both sides.
Take in account Paolo's note you may need 4 BRIs, usually 384 kbps is the Video bandwidth without overhead.
Hope to help
Giuseppe
Hi Giuseppe,
Thanks for u r reply.
I need one more clarification:
Can we connect 2 no.s of 1760 Router in same loaction with 2 BRI ckts
connected on each router and is it possible to use all BRI's (2+2)
total Bandwidth (512 Kbps) for a Video call?
Hello Krishna,
this would require a feature called multichassis multilink.
But:
a) I doubt C1760 supports it
b) I think it works only inbound (receiving a call not making it)
see
http://www.cisco.com/en/US/docs/ios/dial/configuration/guide/dia_multichassis_link_ppp_ps6441_TSD_Products_Configuration_Guide_Chapter.html#wp1043334
Restrictions for Implementing Multichassis Multilink PPP
•Dialer profiles are not supported with MMP.
>>>•Dial-out is not supported with MMP.
•MMP supports PRI, BRI, serial, and asynchronous interfaces only.
using Feature Navigator
www.cisco.com/go/fn
search by feature
multichassis multilink PPP
the starting platform is 1805
(however, 1760 is out of sale)
Hope to help
Giuseppe
