07-30-2007 04:16 AM - edited 03-03-2019 06:05 PM
I'm using GTS (Generic Traffic Shaping) on interface (I would like to limite trafic to 2MBps), and I would like to configure WFQ, which is the default algorithm working with GTS. But I can't succeed to configure the size of the queue. Do you know how can I do?
07-30-2007 05:32 AM
As I know the WFQ cannot be configured just can be enabled or disabled by fair-queue (or something like that) command on per interface basis. This flow based qos technique classifies the traffic and you will have a queue for each flow and the scheduler will service each queue by some algorithm. You don't have the option to influence it.
Hope it helps, rate if does
Krisztian
07-30-2007 06:41 AM
My experience is GTS uses WFQ within the shaper itself. Don't believe you have any control over its WFQ settings. Something you might need to check with TAC.
