Hairpin NAT - IOS-XE (CSR1000v)
bstaton
My environment is using CSR1000 virtual routers, running IOS-XE 13.6 and I am having trouble getting hairpin NAT working, and could use some help.
I have a pretty standard NAT setup as illustrated below (ignore the router/switch models, I just used packet tracer to illustrate)
The main issue is that the 'Local Client' cannot browse to the web server in his own LAN using the global NAT address, which the DNS in my environment is serving up, but the 'Internet Client' has no issue. Additionally, using the private IP, the 'Local Client' can connect, as expected.
From what I've been reading on the support forums, I need to configure hairpin NAT, however, the recommendations for setting up NVI, or using the loopback method, don't work on IOS-XE, and the only solution I've seen mentioned is using VASI, but I'm not sure how to set that up and could really use some help.
I've also heard of solving this issue using split DNS, having a DMZ, or simply just editing the hosts file for the local clients, but these aren't options I'm able to use, unfortunately. I'm open to alternatives, however, if there is a better way to avoid this problem entirely. :)
Here's the relevant config of my NAT and interface setup:
interface GigabitEthernet1
  ip address 123.0.0.1 255.255.255.252
  ip nat outside
  no shutdown
interface GigabitEthernet2
  ip nat inside
  no shutdown
ip nat inside source list 150 interface GigabitEthernet1 overload
access-list 150 permit ip 192.168.1.0 0.0.0.255 any
ip nat inside source static tcp 192.168.1.2 80 interface GigabitEthernet1 80
Thanks in advance for any help.
Brandon
ebenav11
Do you can try add ip host entries in the Border router?
In the NAT environment you need two zones (in/out) for to create the translation tables.
Kind regards
Hi There, Im running the same IOS-XE on a 4331 and have the exact same issue.
I want to use the Public IP in requests made internally. Externally, it works fine using my NAT configurations.
