Hardware Redundancy between sites
tarik.cisco
Hello everybody!!!!
I'm desinging a network for 2 eletric substation following some specifications. (see topology.jpg)
I need to provide fully hardware redundancy between two eletric substation, provide encryption and VPN.
I'm planning to use Two cisco 1841 router with AIM VPN module and more 4 ethernet ports at each site.
This network is for security system (CFTV). Will have multicast traffic and some TCP traffic between sites, so I will use GRE Tunnel + IPsec to pass multicast packets.
For hardware redundancy I'm planning to use HSRP + IP sla command to verify the connection.
My client ask me to use NHRP, but i'm not sure how do I will implement NHRP in this solution ? It is not a point-to-point connection When I use GRE Tunnel + IPSec  ?
Why I need to use NHRP in this case??
I appreciate if anyone could help me!!!
Thanks everybody!!!!
I don't think it will help at all with mcast. Your inital design should work just fine as well.
6 Replies 6
Collin Clark
What is the WAN cloud (ie MPLS, frame relay)? Generally speaking NHRP is used mostly in NBMA WAN.
The WAN cloud is Frame Relay links.
Do I need NHRP to redundancy works fine???
NHRP will help in this case ???
I was informed that will have mobile users acessing network from notebook remotely, NHRP will help them?
TKS a lot!!!
Collin Clark
Maybe, depends on your overall network design. Here's a great article on what it does and you should be able to determine if you want it or not.
http://www.netcraftsmen.net/resources/archived-articles/433.html
I understood that with HSRP one router will be as standby gateway for the other site, so always two routers (one of each side) will be in standby status correct??
I was informed that will have mobile users acessing network from notebook remotely, NHRP will help them???
I'm reading the article know , thanks again!!!
I can't see what NHRP could help in this case??? There are only 2 sites, both sites have statics IP, there are two routers at each site to do hardware redundancy. Will NHRP help in multicast traffic between sites???
TKS
