Have two sets of Public IP and can't access the internet
shanemcanuff
I got two sets of public IP from my ISP, one /30 and /24. I have a 2811 router which is connect to the ISP cisco switch. On my router I have the /30 and and the next interface is the /24 which is connect to a switch. I can ping my ISP GW and DNS servers but I can't access the internet. Can anyone look at my config and tell me what I am missing.
EDGE-Router>en
EDGE-Router#show run
Building configuration...
Current configuration : 3335 bytes
version 12.4
service password-encryption
hostname EDGE-Router
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
ip cef
ip domain name yourdomain.com
archive
log config
hidekeys
interface Loopback0
no ip address
ip nat inside
ip virtual-reassembly
interface FastEthernet0/0
description LINK TO ISP
ip address 69.177.74.206 255.255.255.252
duplex auto
speed auto
interface FastEthernet0/1
description LINK TO ARTNET INTERNET SWITCH 23RD FLOOR
ip address 69.177.131.2 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/0/0
interface FastEthernet0/0/1
interface FastEthernet0/0/2
interface FastEthernet0/0/3
interface Vlan1
no ip address
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 69.167.64.205
ip http server
ip http access-class 23
ip http authentication local
ip http timeout-policy idle 60 life 86400 requests 10000
ip access-list standard outside-nat-inside
permit 192.168.0.0 0.0.0.255 log
permit any log
access-list 23 permit 10.10.10.0 0.0.0.7
control-plane
line con 0
password 7 002501120A5E1F540472
logging synchronous
login
line aux 0
line vty 0 4
access-class 23 in
privilege level 15
password 7 13240506050910782077
logging synchronous
login
transport input telnet
line vty 5 15
access-class 23 in
privilege level 15
login local
scheduler allocate 20000 1000
end
12 Replies 12
Jon Marshall
Shane
This is a bit confusing. Your default route points to 69.167.64.205 which is the other end of the /30.
So what are you trying to achieve with the /24 ?
Jon
With the /24 I want to connect any systems that is connected to the switch on that interface to access the internet or I can access it from the internet since the /24 I have are public IP
69.167.64.205 sorry I mean 69.177.74.205 is the ISP gateway. from my router I can ping www.goolge.com but when I connect to the swicth which /24 is connected to I can ping up the the ISP gateway and DNS servers but can't access the internet.
Verify your ISP has a route back to your /24 subnet, if they don't - the internet won't know how to get back to you.
Your config is fine.
BTW, where are you implementing NAT in your network?
__
Edison.
Edison, I was thinking to do NAT but since two set of IP's are public do I have to do NAT?
Shane
No, you shouldn't have to.
As Edison says, your config looks good. Assuming you have the default-gateway etc. correct on your /24 subnet clients i would check with your ISP.
Have you ruled out DNS ie. have you pinged google's IP address rather than URL.
Jon
If every device internally is going to be on the public /24, you don't need NAT but I find it odd that you will use a public /24 for your internal network. What type of business environment is this? Hosting services?
BTW, I agree with Jon - try pinging an IP instead of name from the switch holding an IP from the /24 subnet. Try pinging 4.2.2.1
__
Edison.
Shane
Are you sure the ISP is routing the /24 back to you ?
Jon
Edison Ortiz
Your default route is incorrect.
Based on the IP address on the WAN interface
it should be
ip route 0.0.0.0 0.0.0.0 69.177.74.205
the ip route 0.0.0.0 0.0.0.0 69.167.64.205 was a error I typed. the ISP gateway is 69.177.74.205.
Thanks a lot guy, I call my ISP and for some reason the engineer forget to route the /24 to me.
Shane
Yep, that would do it :-)
Glad you got it sorted.
Jon
