HDLC Messages
bktkruppw
We just started having issues with one of our T1's.  We are getting the following error messages doing a debug service-module and debug serial interface:
Jan  1 22:46:03.456: Serial0/0/0: HDLC myseq 109, mineseen 106, yourseen 95, line down
Jan  1 16:46:04: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/0/0, changed state to down
Jan  1 16:46:04: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 10: Neighbor 192.168.200.30 (Serial0/0/0) is down: interface down
Also getting theses errors:
Jan  1 22:44:48.142: Serial0/0/0 - Keepalive time mismatch - should be 10 secs, is 29
The keep alive is set to 10seconds.
Any ideas?
paolo bevilacqua
Please include "show interface serial X/Y/Z" taken on both sides of the circuits.
bktkruppw
Serial0/0/0 is up, line protocol is up
  Hardware is GT96K with integrated T1 CSU/DSU
  Description: T1 to Nelson 41.HCGS.100022.KEND
  Internet address is 192.168.200.29/30
  MTU 1500 bytes, BW 1536 Kbit/sec, DLY 20000 usec,
     reliability 168/255, txload 1/255, rxload 1/255
  Encapsulation HDLC, loopback not set
  Keepalive set (10 sec)
  Last input 00:00:01, output 00:00:02, output hang never
  Last clearing of "show interface" counters 02:00:29
  Queueing strategy: weighted fair
  Output queue: 0/1000/64/0 (size/max total/threshold/drops)
     Conversations  0/2/256 (active/max active/max total)
     Reserved Conversations 0/0 (allocated/max allocated)
     Available Bandwidth 1152 kilobits/sec
     10090 packets input, 783348 bytes, 0 no buffer
     Received 380 broadcasts, 0 runts, 0 giants, 0 throttles
     6628 input errors, 6628 CRC, 1155 frame, 1087 overrun, 0 ignored, 1045 abort
     11892 packets output, 961150 bytes, 0 underruns
     0 output errors, 0 collisions, 76 interface resets
     0 unknown protocol drops
     20 carrier transitions
     DCD=up  DSR=up  DTR=up  RTS=up  CTS=up
  Internet address is 192.168.200.30/30
  Last input 00:00:00, output 00:00:00, output hang never
  5 minute input rate 1000 bits/sec, 2 packets/sec
  5 minute output rate 2000 bits/sec, 3 packets/sec
     21855 packets input, 1818527 bytes, 0 no buffer
     Received 1441 broadcasts, 2 runts, 1 giants, 0 throttles
     624 input errors, 623 CRC, 191 frame, 112 overrun, 0 ignored, 225 abort
     22931 packets output, 1783532 bytes, 0 underruns
     0 output errors, 0 collisions, 30 interface resets
     17 carrier transitions
The circuit is having so many errors that can't be reliable.
Is telco providing clock ?
If they are not, are you providing clock on one side only ?
The other obvious chance is, faulty circuit.
